Results 1 to 15 of 19
    Mar 2010
    Holly
    Mercury Cleavers
    Is there a reason that Merc doesn't make a 36 3 blade Cleaver? im hitting the limiter pretty hard with my 34 and would love a 36.... any thoughts on this?
    21 Skater w/ 250SHO
    I believe it has to do with efficiency. I read years ago that the most efficient prop is "squared" in measurement. For example 14X28 or 15X30, etc. so when you get that far away from double the diameter, the prop becomes less and less efficient. No idea if this is actually true, but it sounded pretty good
    Mar 2010
    Holly
    Interesting concept. i have heard from a few people that big cleavers i.e 34's run high slip numbers.. i think i'm around 9% right now with the 34 so lets say they had a 36 at 12% it would still be faster..
    heres where the yamahas lack... i need 1.62 gears then a 6150 limiter wouldn't matter. but instead yamaha dropped the ball and only has 1.75's and a un removable limiter. RIDICULOUS !!
    21 Skater w/ 250SHO
    Quote Originally Posted by Jamescole View Post
    For the truely impossible problems, you need to call in the First Team. I would dispatch a PM to Mr Yamamoto himself, AKA the Superbender, things that can't be accomplished by mere mortals can be done with a simple flick of the wrist by him
    upstate N.Y.
    Eric's my hero!!!
    why ask me ?
    Aug 2004
    Venice, Florida
    I had Rich Junker add some "bite" to a cleaver I ran and it acted a little bigger without really changing the way it ran. I believe he put some more angle at the trailing edge and a little rake out in the tips. You might talk to him or one of the others good prop guys about tweaking your 32.
    21' Paramount
    Mercury 300 Promax
    6250.... I feel your pain...... Oh and BTW 1.62s will probably NOT solve your limiter problem if you can hang onto it.
    After some work, a "34" or "36" can make the "prop calculator" say 5%
    Sep 2002
    Parry Sound, On
    They make up to 40 in the CNC 5 blade cleavers......time to step up your game...
    '08 SRV
    Yamaha 3.1 Phase III
    Mar 2010
    Holly
    Quote Originally Posted by DoktorC View Post
    maybe if i was made of money.... at that point it might be Worth a try.... you need to start working on getting a 1.6 somthing (or smaller) gear ratio in these things.. sportys seem to piss off every week, if i went that route (you already said it) id be broke for sure.
    21 Skater w/ 250SHO
    Owen Sound Ontario
    A 2.5 case would be the only way to go..... Ken eats 3.0 cases for breakfast. Merc really f'd up on that one... My OLD Yamaha fishing gears outlast 4 3.0 sporties.. lol. I would think baja200merc would be the best guy to talk to on solving the issue.
    Mar 2010
    Holly
    i solved my issue....
    21 Skater w/ 250SHO
  12. #12
    Aug 2004
    Venice, Florida
    Nice. Who did your mid?
    21' Paramount
    Mercury 300 Promax
  13. #13
    Mar 2010
    Holly
    Quote Originally Posted by Mr. Demeanor View Post
    its a new motor. its a Hydrotec 16"
    21 Skater w/ 250SHO
  14. #14
    Looks good, no more HPDI?
  15. #15
    Mar 2010
    Holly
    for now no more HPDI... once simon or someone else figures it out ill put the HPDI on it.
    21 Skater w/ 250SHO
