Results 1 to 7 of 7
    Sep 2007
    Denmark Fyn Hasmark beach
    Efi 2.5 race RPM 6000 missing rmp overheating
    After running the Quicksilver DDT tester, we have a few things to sort out. When running the auto self test, all chapters injectors, sensors etc. says Pass= normal function.
    When we chek the break-in status it says engine is in (break-in 4minutes) this engine is without autolube, does engine brake-in mode do anything else than ajust the oil injection ? reduce RPM ?
    When select the 7-RPM Limit it says all off, but when enter the menu in says RPM limiter active due to overheating, the we press help to get the diagnose it says chek all ground connecters,is that a “common answer for this diagnose ? or can it be a malfunction temp. sensor or etc.
    Kindly
    Anders Blacha
    And /Lasse
    Western Pennsylvania
    What year... which engine u got
    http://www.stvowners.com
    2003 Cougar 22MTR w/300xs x 3
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Sep 2007
    Mercury 2.5 ros 1998 with motorola EFI S69701 date 07 /02/1997
    Old River , Texas ( 35 mi East of Houston )
    If your ROS has been "reset" OR is new and hasn't reached a break in point it will run lazy until that point has been reached. It would be hard to understand why a 5 year old motor/ecu has not been ran long enough to reach break-in UNLESS someone has set the ECU on "re break-in" then you'd have to start all over again with the long brake-in.....
    Jay
    Jay @ JSRE
    Sep 2007
    Hello best Company Jay Smith Racing. What is ROS short for ?
    Does break-in adjust anything else that the quantity of oil ?
    The DDT tell us that break in mode deliver more oil during the break-in and nothing else, but this engine does not have autolube system (premix)
    Kindly Anders. The ecu has been repaired and maybe this way its in break in mode. I try to let it run more.Kindly Lasse
    Dec 2012
    Norwegen
    Hi Iv saw this on a mercury 525efi yesterday also, it was excactly 4min left brakein on a engine that had some 80hours on it, think this is just a programming fault the have done. Do you have the right cartridge for this engine? A good idea is to skip the auto selftest, go straigth to data monitor and see all the valies there like temp sensor for air and sylinder heads are quite equal and true to the outside temp when the engine has not been used. When you say ecm has been repaird, what does that mean? Best regard Anders
    When it comes to propellers, I hate Choppers!
    -Sunwind 480 race boat 90 omc- Sold
    -Tintopieta 20 race boat with 90 yam-Sold
    -B-19 batboat with 90 yam-Sold
    -B-23 batboat with Merc 200xs-Sold
    -B-28 Batboat 662 merc sci- Present
    -Twister 24 Special edition Merc 200XS ROS - Present
    -Twister 24 Merc 200XS ROS - Present
    Gothenburg, Sweden
    The ROS ECU does not care about the overheat alarm, from what I remember.
Spinelli Props
