Results 1 to 4 of 4
    Jul 2013
    Athens, TN
    trailer vibration.
    Hey guys I have a 17v bullet that w/ motor and all weighs maybe 1400lbs with a full tank. Right now is on single axle heavy duty trailer thats rated for at least 3,000lbs. when going down the road at about 50-55 a bad vibration occurs and actually shakes the trolling motor violently enough to flex the boat where its mounted. The guy that had this last put some odd radials on it. My question is would getting a set of loadstars fix this or is this a combination of the tire and heavy leafsprings causing this? sadly i cant get a trailer made for the boat or i would in a heartbeat.
    1984 17vee Bullet w/1985 Johnson 150gt (bob's nose cone, hydrodynamics custom 8in. jackplate, custom skid plate and foil, and 26p trophy plus) currently 70mph tournament loaded.
    Sep 2009
    Lake One
    These have solved all our tire balance problems on several different trailers. Good for the tow vehicle as well.
    "have you met my little fly named scream?"
    GSE #1 2004 GSE, 2004 225X Promax... RIP
    GSE #2 2013, Gen2 200XS ROS
    check tire balance on trailer tires...
    TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
    DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
    LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
    Jul 2013
    Athens, TN
    you know what i completely forgot about balancing tires my jeep never has needed it in two sets of tires.
