Results 1 to 15 of 24
    edgewater fl
    30 pitch cleaver or 30 pitch chopper?
    I want to know what would be better on a 4 seater mirage with a 2.5 200 which would make it faster 30 pitch cleaver or 30 pitch chopper
    Apr 2013
    Secord Lake MI
    Cleaver would be better in a long run by yourself. Chopper would be faster in a short run 3/4 of a mile. Chopper gives boat more bow lift. Cleavers lift the stern.
    edgewater fl
    what prop would you use if u had a 4 seat mirage? I'm trying to hit 90mph!!!!
    edgewater fl
    can any body tell me wat the best prop would be to use on my boat?
    Sep 2002
    Use an ET... The best of both worlds.
    Yamaha Drags work good too, especially for holeshot and acceleration.
    Apr 2013
    Secord Lake MI
    Quote Originally Posted by scottturner View Post
    Props are a matter of trial and error. I would try the chopper myself first. What prop are you running now and what rpm are you turning and top speed?
    Set up and altitude are big factors, seen boats that run great with cleavers at below 1000' once you get to 14-1500' the cleaver wont work. The air gets thinner and air is not as hard so the bow lift of the chopper is needed at higher altitudes.
    Aug 2002
    Palm Harbor, Fl../ lake tarpon
    if ur not hitting 90 with a 200 there is more to worry about than the chopper or cleaver,but yes a round ear prop is gonna help ya out first, 2nd what is the jack plate set back ,height,lower unit u are running
    02 mirage ski racer w/ 2.5
    lake tarpon (LTB racing)
    "Mirage Boats... often imitated but never duplicated"
    edgewater fl
    I am running a 28 pitch prop and hitting the rev limiter at 5600 rpm's when hitting top speed
    Sep 2002
    5600 limiter?? Huh?
    Dallas, TX
    With that limiter, sounds like a newish 200. Maybe an Opti?
    Run the chopper with that motor. If you end up removing the limiter then you might try a ET or Cleaver.
  12. #12
    edgewater fl
    Its an a 2002 200 Efi with a 9 inch set back, running the prop shaft a half inch below the pad, with a sport master fat shaft 1:87:1. Also who would I send the rev limiter to for them to remove and where are they located I've been trying to find someone to do it ?
  13. #13
    Dallas, TX
    http://www.simonmotorsports.com Give Eric Simon a call, he's probably your best bet.
  14. #14
    edgewater fl
    I'll give him a call thank you
  15. #15
    edgewater fl
Spinelli Props
