Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    Jul 2013
    North of 54 parrellal
    Some have one tps but mine has two of them bolted together with a throttle linkage in the middle
  2. #17
    Jun 2013
    san luis obispo, ca
    Okay I see the diagram of yours with 2 TPS. Each one has 2 different part numbers so I assume the must be a difference between them. If this is so I would think they would not fit together unless put in the correct location? But also is it possible you were plugging the wrong wire plug in? If you are sure you had that correct than it certainly is possible one of the new ones you purchased is no good. I agree with the WTF! I Go WTF all the time with this stuff.
    [SIGPIC]
  3. #18
    Jul 2013
    Yes they are plugged into the right sensors you cant mix them up I guess its if it can go wrong it will?
  4. #19
    Jun 2013
    san luis obispo, ca
    Well then it's a WTF for sure. Regardless you got it working. Congratulations!
    [SIGPIC]
  5. #20
    Jul 2013
    I am still getting a code once in a while still cause the tps1 and tps 2 came up and all i changed is tps 1
  6. #21
    Jun 2013
    san luis obispo, ca
    The problem would have to be with the wire harnesses or the sensors.
    [SIGPIC]
