Results 1 to 1 of 1
07-04-2013, 08:18 AM #1
16' Laser basser...15" or 20" mid
Anyone have experience or words of wisdom on which to use on a lightened 16' laser vhull with a pad. End result I am looking for is good hole shot with real good top end numbers. Going with a 2.5ltr prolly XR6. Several of them around here I can acquire. All I am going to do with motor is good rebuild,clean up the ports by removing casting flash,install 200 tuner and low water pu. Maybe cut and cc heads and jet accordingly.
With what I am doing to hull I should be looking at high 70's maybe even low 80's. With either the15 or the 20" would what gear set would y'all suggest. I know where there is the 1.68's,the 1.72'sor whatever that number is or the 1.87's. as far as props I wanna give a chopper arty first with one of the specialty cuts to help out with stern lift and not mess with the bow lift to much. We all know what happens with to much bow lift on a laserLaser 1550 ...under construction with a serious weight loss
Motor 2.4....undecided on hp yet
