Results 1 to 9 of 9
    Mar 2013
    Seattle, WA
    Velocity 21' 300x Prop Question
    I have a 21' Velocity with a Mercury 300x and having trouble pulling skiers out of the hole. Running a Mazco HP4 4 blade 24 at about 6400 Rpm at WOT. About 70 MPH.
    Boat bogs down pretty hard before it starts to plane. 4-5seconds of very low RPM before it loosens up. Any suggestions? Thinking about pitching down to a 4 blade 23.
    peabody mass
    maybe to much bite with the 4 balde i would try a 3 blade mirage more slip out of the hole
    Sep 2010
    long island,ny
    Bravo I with pvs holes is great for hole shot and skiing.
    1990 22' Activator Yami HPDI 300-sold
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat
    1990 22' Activator yami OX66 Vmax 250
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold
    Aug 2005
    port orchard , wa
    Your boat if its the one im thinking it is,is the cleanest and nicest Velocity around bar none.For skiing just get a 23 trophy plus and itll pull no problem.The boat will run 80 once you learn to drive it.Congrats on the purchase Id bet the seller may have mixed feelings down the line I know I would of.
    FL / NY
    I had a 1985 22 with an X and ran a 24 Trophy Plus and a 24 Bravo 1. They both ran similar but the Bravo was 2 faster up top. Only had the motor on it for a week so did not do much dialing it in. I agree for what you are looking to do you need a 4 blade prop and depending on the load you will be carrying you will need a 23,24.
    Are you running a Sportmaster 1:62? You may benefit running a stock torquemaster!
    Mar 2013
    Seattle, WA
    Thanks for the advice. Yes it's the clean velocity out of Gig Harbor. I'll give the 23" trophy a shot. Thanks again.
    Sep 2010
    long island,ny
    Quote Originally Posted by erikboyll@gmail.com View Post
    Bravio 1 ...pulls like a freight train (needs 4 pvs holes) and will give best hole shot for skiing and heavy weighted boat take off. JMO
    1982 21' Superboat
    Aug 2004
    Venice, Florida
    If the HP4 doesnt have vent holes, that is what I would do first before buying another prop.
    I have a small Yamaha NOT a small Johnson
    Jun 2002
    Northern Utah
    I second the Bravo I with PVS holes for skiing/heavy loads. I'd go with 8 PVS holes since you'll probably need more than 4 open.
    If you have 1.87 gears you are at 10 % slip with the HP4. If you have 1.62 gears, you have 22% slip and therefore have prop or setup problems.
Simon Motorsports
