Results 1 to 15 of 17
06-17-2013, 06:43 PM #15000 RPM
- Jun 2002
- Vancouver, BC
- 882
- 32
- 27
- 52
- 99
280 with Drag Electronis, will not pull past 6000rpm if throttle mashed from takeoff
I have a customer who has just installed a clean, used 280SS, with Drag Electronics on a Cougar Omega... If you accelerate gradually, it will pull all the way up to over 9000rpm with a 26 Yamaha, he's swapping to a larger prop to bring it down a bit... however, if he punches it from about 3000rpm or less it hits a wall at about 6000-6300 and will not run up any higher, it sort of surges like it wants to go but just won't go... if he lets off the throttle lets it come back down to 3000rpm or so and roll into it slowly, its pulls all way up and over 9000rpm... OK guys... what do you all think is going on?
Mike Nass
Haulin Nass RaceBoats (HNR)
www.haulinnassraceboats.com
e-mail - MikeNass@shaw.ca
phone - 604-230-4835
06-17-2013, 08:27 PM #2Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
What ecu? That's an odd problem
Erik Kiser
06-17-2013, 08:39 PM #3
I would think the ecu maybe the problem
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
06-17-2013, 08:55 PM #45000 RPM
- Jun 2002
- Vancouver, BC
- 882
- 32
- 27
- 52
- 99
A6 ECU... Also, they checked fuel pressure and it stayed right solid at 56...
Mike Nass
06-17-2013, 09:40 PM #5Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Do you have anyone up there that can check the curve in that ecu or put another one in it. I'm thinking out loud here and maybe RBT will get in here but under full throttle you are operating on the top line or two of the fuel curve. If the box is corrupt sometimes a random number or a few may have some really odd numbers, sometimes may be a 0 where there should be a 145 or could be a 255 where there should be a 145(just using 145 as an example). When you ease into it the motor is still pulling some vacuum so you aren't running off that top load value line. I know it sounds Greek if you haven't seen a fuel curve but there's a chance that could be the issue. I'd try another ecu
Erik Kiser
06-18-2013, 12:09 AM #65000 RPM
- Jun 2002
- Vancouver, BC
- 882
- 32
- 27
- 52
- 99
Mike Nass
06-18-2013, 06:23 AM #7Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Is your customer in the States or Canada
Erik Kiser
06-18-2013, 10:52 AM #85000 RPM
- Jun 2002
- Vancouver, BC
- 882
- 32
- 27
- 52
- 99
he's in Canada... West Coast...
Mike Nass
06-18-2013, 03:52 PM #9
Weird, mike check your pm's
2023 TUFF 25
06-18-2013, 10:36 PM #105000 RPM
- Dec 2011
- TALLY,FL
- 199
Defineatly an odd problem to have . Can't wait to hear the outcome. This will help in the future I'm sure.
06-19-2013, 12:30 PM #11
I had a brucato acu lose half of the fuel curve. And ran fine but only to like 3000
06-19-2013, 12:52 PM #125000 RPM
- Jun 2002
- Vancouver, BC
- 882
- 32
- 27
- 52
- 99
Thanks guys, Erik I think you hit the nail on the head... we sent ECU off today... we'll see how things are when it returns...
cheers,
MikeMike Nass
06-19-2013, 01:23 PM #13
How big is the "larger" prop he put on?
XR2001 & XB2002
07-18-2013, 08:19 PM #145000 RPM
- Jun 2002
- Vancouver, BC
- 882
- 32
- 27
- 52
- 99
Just to close the Loop, Erik, you were right on the money, corrupt fuel map... not sure how it happened, but sent to Tony Brucato and they found it was corrupt with zero values in much of the map.... he reflashed it and it runs great!
cheersMike Nass
07-18-2013, 08:49 PM #15
If it is a Woodward box, they don't seem to like magnets...... Like flywheels
2023 TUFF 25
