Results 1 to 6 of 6
Thread: 28 SPL Evinrude
06-16-2013, 03:08 PM #1
28 SPL Evinrude
Bought a 28 SPL Evinrude. What does SPL designate? I assume this is a 100:1 motor. Drained lube and it was black and smelly but no metal or water. Can I use Merc Gear Lube+ or is there something specific. Motor started and ran fine for a minute then would not hardly run. Took carb apart and removed about a pound and a half of crud so it should be fine now. I have owned several OMCs but this is the first one I have used. Anything I should watch or look out for other than the usual things. Thanks
RockTeam Junk
06-16-2013, 03:44 PM #2
SPL = special... SPL's were stripped down/basic models. I depends on what hp/model/year as to what would make it a SPL motor, typically SPL's didnt have oil injection (VRO), PT/T, had the smallest charging system available for a particular motor etc...
Your gonna want to mix at 50:1, Merc L.U. lube is fine... Their great motors!Dan Cario
1994 STV Mod-VP w/225HO Ficht Evinrude
1987 22' Velocity w/225HO Evinrude E-Tec
06-16-2013, 08:44 PM #35000 RPM
- Dec 2012
- Moses Lake, Wa.
- 156
28 SPL(special) were 30 ho powerhead with 25 hp gearcase. Nonthu-hub. originally 100/1 fuel oil ratio that OMC scrubb'd and modify'd to 50/1, remote control only, no tiller models.
06-16-2013, 09:33 PM #4
They last forever
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
06-17-2013, 05:21 AM #5
Someone's
Pole
Licking?Sunsation 32 Dominator - 496 MAG HOs
Nothing runs like a Deere when a CAT's on it's ASS!
06-17-2013, 05:42 AM #6
OH NO a Heathen with a Johnnyrude!!! The Sky is going to fall
Sorry Randy couldn't help myself Buddy .
SPL. Over the years I've heard many versions as one of my best buddies Dad was a OMC dealer.
Special Styling Long Shaft. Standard Pre-Mix Long Shaft
Basically they were stripped down derated in HP from their more upscale models. They were marketed for the Waterman and at one time was OMC's top selling line. Rock Solid Motors for sure.Last edited by HStream1; 06-17-2013 at 05:44 AM.
