Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
    Jun 2013
    Mesa, AZ
    Haha well maybe I have my starboard and port mixed up then. Lol. Sitting in the boat, left is port and right is starboard, correct?
  2. #17
    Jun 2013
    Mesa, AZ
    Or maybe I have the cyl numbers mixed up? Book shows me that #1 cyl is left(port) top??
  3. #18
    Apr 2010
    USA
    Ha. Please, someone chime in here and verify the points discussed. I know others are reading this.
  4. #19
    Apr 2010
    USA
    Hey Sleek, what book are you looking at? Just wondering.
  5. #20
    Jun 2013
    Mesa, AZ
    When I get home I will get the details on it.
  6. #21
    Ft. Lauderdale, Fl
    How are the magnets on the flywheel? they tend to come loose and cause all kinds of havoc..........
  7. #22
    May 2001
    The Villages, Florida
    The reason it controls top and bottom is the box is the same as a v4 thus fewer parts to stock, originally they had different numbers for top and bottom later all had the longer wires for bottom. Odd of a timer being bad on 4 cylinders is very low generally they will lose only 1. You need a peak reading voltmeter to properly check the system. 1 is the highest cylinder top starboard
  8. #23
    phoenix, az
    BAM!!! There you go Sleek69...Your answer.
    Now, can he swap packs side to side to see if the problem follows the packs? Assuming the primary coil wires are long enough?
  9. #24
    Apr 2010
    USA
    OK, and you guys know very well that goes against all OMC engine design practices. No other OMC I ever heard of has top and bottom controlling powerpacks. All are side to side. Great to know tho. Thanks Racer.
  10. #25
    Jan 2003
    aalsmeer
    ignition guide?
    Attached Thumbnails Attached Thumbnails CDI+Troubleshooting+Guide+-+2012_1.pdf
  11. #26
    phoenix, az
    Quote Originally Posted by tvd View Post
    Along with the exhaust separated top 4 and bottom 4. The v8s definitely didn't fit with the 4s and 6s.
    Then again, they basically stacked two v4s on top of each other. So maybe the 6 doesn't fit???
