Results 1 to 7 of 7
Thread: 20 hp cougar cub
06-10-2013, 08:52 PM #1Junior Member
- May 2010
- Pennsylvania
- 9
20 hp cougar cub
were can i find a prop for 1969 mercury 200 20hp on 1984 cougar cub 10' tunnel hull currently 9 7/8 x 10p 8 spline over reving @ 26 mph was thinking 13 - 16 pitch. thank you paul.
06-20-2013, 11:14 PM #2Junior Member
- Jan 2013
- australia
- 27
Is this the stock ally prop? i had a 80s 25 merc on my cub which had the stock prop and im sure it went much quicker then 26mph.
Im sorry i cant help you with finding a prop as im from australia but id sugest ebay maybe?
And id personally go with the 16 over a 13.
What do you use your cub for?
06-21-2013, 12:28 PM #3Supporting Vendor
- Nov 2006
- bradenton ,fla
- 412
06-23-2013, 09:02 PM #4Junior Member
- May 2010
- Pennsylvania
- 9
tried other prop this weekened with disapointment ran 23 mph @ 5800 rpm motor just reved up from start off 5500 rpm and slowly planed off was a 2 blade bronze 9' x 16pitch ,
06-24-2013, 09:21 PM #5Junior Member
- Jan 2013
- australia
- 27
With the stock prop on my 25merc we were getting faster then that. Have you played with engine hight? Do u have trim? We would find if i went out with the motor in the 5th hole it would just cavitate like hell. Maybe try less trim.
06-24-2013, 09:23 PM #6Junior Member
- Jan 2013
- australia
- 27
May i add we could pull a 130kg bloke on a knee board or biscuit at a decent speed
07-16-2013, 09:43 AM #7Junior Member
- May 2010
- Pennsylvania
- 9
This week tried 10×13 pitch cupped prop & replaced ignition points running smoother , but still only 28 mph @ 5300 rpm.
