Results 1 to 15 of 35
Thread: 300 promax to 300xs question
06-03-2013, 05:21 PM #1
Is it possible to put a 300xs power head on a 300 pro max mid? I'm sure it wont line up correctly or will it? And if not, can you make an adapter for it?
21 Action with a 300xs
06-03-2013, 08:16 PM #2
Yes, it will work. All you need is an XS powerhead ( i know where a bunch of drop-ons are ) and a 300xs exhaust adapter plate. You already have the potatoes of the project- you just need the meat.
NICE PAIR liked this post
06-10-2013, 07:55 PM #3
This caught my eye. So, you can drop a 300xs powerhead onto an existing 300x mid? I just cooked my 300x, and the fuel milage is way better with the XS. Where can I research this further? Interested!
06-10-2013, 11:32 PM #4
06-25-2013, 09:28 AM #5
06-25-2013, 09:30 AM #6
Where can I find a used 300xs powerhead?
'72 Glastron GT-150 Johnson Stinger 65
'83 Hydrostream Varmint 2.4 225 Mercury
'05 Hydrostream Voyager 250xs optimax
06-25-2013, 03:05 PM #7
06-25-2013, 09:06 PM #8
06-26-2013, 06:14 AM #9
Cowl X meant stock X cowl or promax cowl. you could use the 2 piece skirt from an XS since the X adapter plate has the " ring" to except the skirt gasket however some trimming would be required to the skirt and honestly would look pretty bad since the X exhaust housing is so fat and none of the lines would match up.
I just finished another 15" mid I built it for my 300XS . All new stock Merc parts w/ a Taylor exhaust housing. Nothing is cut or chopped. The 15" swivel bracket is from a 200XS ROS since it uses the same trim sender.
06-26-2013, 06:30 AM #10
That sounds like a sweet motor. Do you have any pics of it?
06-26-2013, 06:59 AM #11
06-26-2013, 07:04 AM #12
To anyone doing the conversion from an X to XS powerhead- make sure you pickup either a stock XS tuner or a DBR tuner.
I would not recommend cutting a stock XS tuner if you have a 15" mid... go with the DBR tuner.
06-26-2013, 08:47 AM #13
06-26-2013, 09:06 AM #14
06-26-2013, 10:20 PM #15
