Results 1 to 2 of 2
Thread: Help plse
06-01-2013, 08:14 AM #1New Member
- Jun 2013
- apollo beach
Help plse
2001 OPTI 225 wont run wot surges bad also when idling in gear and you trim up or down motor picks up 800-1000 rpms
06-01-2013, 11:32 AM #2
Check your fuel system for air leaks, restrictions or contamination such as water. Check/ replace the fuel filters. Surging at high speeds usually is a fuel delivery problem. As for the idling, don't know, maybe check your battery connections (just a shot in the dark) and condition of the battery and charging system. A lot of people put their batteries in using the wing nuts and don't get them tight enough.... loose battery connections can cause all kinds of havoc in electronic engines.....
