Page 72 of 105 FirstFirst ... 22 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 ... LastLast
Results 1,066 to 1,080 of 1571
  1. #1066
    Aug 2004
    Venice, Florida
    Hell yea that's great. 95 will be a cake walk
    This new prop really hooks up hard. Last time 94mph was at 7100rpm which was 13% slip. This prop ran almost the same at 8%. I could probably come up a 1/4" and run 95 right now but Im going to talk to Tim at Performance first. He wanted to cut the blade area down but leave the diameter to reduce the crabbing and tail lift.
    21' Paramount
    Mercury 300 Promax
  2. #1067
    Slip is a theoretical number.... The new prop is a closer to 34 or your tach is off. The numbers hammered on the side of the prop do not tell the whole story
    Either way that boat is very efficient, 99% of 200hp tunnels have trouble going that fast at that RPM with a 1.87. Doing it with a 2:1 is proof that thing is dialed in.
  3. #1068
    Aug 2004
    Venice, Florida
    I had the prop checked by Rich Junker before I ran it. Its a 32 but it has very little progression. Most 32's are 30 at the leading edge, 32 in the middle, and 34 at trailing edge. He said this one is closer to 32 throughout the blade. Thats usually is fast and very efficient with poor holesshot which is exactly how it ran.
    21' Paramount
    Mercury 300 Promax
  4. #1069
    Aug 2004
    Venice, Florida
    Little video of Dago strolling by today cruising across the harbor. I was probably only running about 60. I swear the motor sounds different with each prop I run. A lot of the unique sound of his thing is the prop. Kind of a howl and it seems to change pitch with ..... pitch!
    21' Paramount
    Mercury 300 Promax
  5. #1070
    So your saying your tach is on the fritz and the prop will not lay flat on a 32p block
  6. #1071
    Aug 2004
    Venice, Florida
    Im saying 93mph was pretty damn fast.....but I really want that 95
    21' Paramount
    Mercury 300 Promax
  7. #1072
    Quote Originally Posted by Mr. Demeanor View Post
    #timefora34or1.86
  8. #1073
    Aug 2004
    Venice, Florida
    Would have to change gears and I might have them here. I tried a 34. Wayyy to much pitch and it didnt like it. Tried to paddle wheel that back of the boat around to the front at 90+
    21' Paramount
    Mercury 300 Promax
  9. #1074
    East Wallyworld Vt
    95 is half way through, should just be rounded up to say 100.
    Well for next year then
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  10. #1075
    Aug 2004
    Venice, Florida
    Anyone know what the stock 115/130 compression numbers were? I know the 115 had the goofy head with different compression top and bottom. I took .050 off a stock set of 115 heads and need to take a little more to get my numbers back up. I still have .070 of squish and need about 10-15 more psi.
    I want to say my stock 130 had 130+ psi which seems high but googling it I get similar numbers.
    21' Paramount
    Mercury 300 Promax
  11. #1076
    Aug 2004
    Venice, Florida
    Finally tried something I have been meaning to do.
    Made a wide open pass with my slow prop at 85.1. That prop always run 85 and never faster.
    Took off the velocity stacks and it went 86.5.
    Ray had told me to try without and I keep meaning to do it but just never did. This was back to back same load, water, weather etc.
    That should get me 95+ with the big prop.
    For sale: One set of Kottman velocity stacks
    21' Paramount
    Mercury 300 Promax
  12. #1077
    Mr. D Any idea why she runs faster without the v-stacks? Gary
  13. #1078
    East Wallyworld Vt
    Chris, can you determine how close the stacks are to the cowl? Do you have at least 1½"
    Regards,
    Charlie North
  14. #1079
    Aug 2004
    Venice, Florida
    Plenty of room but could be a number of things. My carbs are modified quite a bit with a "smooth bore" that is almost like a VS so maybe it was like a really long VS. I had rounded the edges of the carbs themselves when I modded them and then Ray sent me the stacks so I bolted them up. I knew there might be a slight difference but it was pretty big.
    You just never know what a motor will like.
    21' Paramount
    Mercury 300 Promax
  15. #1080
    Aug 2004
    Venice, Florida
    It felt better from idle up but its hard to tell seat of the pants.
    21' Paramount
    Mercury 300 Promax
