Results 1 to 15 of 20
    long island , new york
    Adapter Evinrude v8 to mercury harness
    I'm rigging my boat with 2 1989 Evinrude v8s. I bought the boat without motors. It had Merc's on it. I think they were 2.5's The harnesses in the boat have a round connector with 8 pins including one in the center. Is there an adapter harness for this combination. If so what would activate the choke.
    I called CDI. I'm waiting for them to get back to me
    Aug 2002
    Palm Harbor, Fl../ lake tarpon
    just get two omc harnesses and be done with it ,im sure ya can sell the two mercs without a prob
    02 mirage ski racer w/ 2.5
    lake tarpon (LTB racing)
    "Mirage Boats... often imitated but never duplicated"
    Quote Originally Posted by toyomirage02 View Post
    I didn't want to touch the wiring in the boat. It's done perfectly. Under dash and gauges are wired. All secured and neat.
    You can make adapters pretty easily. The merc harness and key switch will do everything the OMC needs. You can either hack off the end of the mercs and splice on the red omc plug or get the motor side of the merc plug and plug it into the boat harness then connect it to the Omc red plug so its all plug and play.
    Aug 2002
    (hack off) like with a meat cleaver lol
    Aug 2002
    hack off them omc's and bolt up some mercs and will be ok
    Aug 2002
    Lowell,IN
    you can buy adapters from kendor marine in Wisconsin. I bought one to run a merc with an OMC harness and a buddy in Wisconsin bought one to run an OMC with a merc harness. cost was $40. there number is (414) 421-4370
    Quote Originally Posted by Superdave View Post
    Why oh why?
    because I built 2 -300 plus hp outboards for approx. 6k
    Quote Originally Posted by outboards4life View Post
    I called Kendor Marine. They need a part #. They only have OE adapters. Example old motor to newer harness. Do you have the part # your buddy used.
    Aug 2002
    Lowell,IN
    I will call him and see if i can get one for you.
  12. #12
    Aug 2002
    Lowell,IN
    Gave him a call, he will check when he gets home and post up a part number for you.
  13. #13
    Hi, I appreciate your help. Your buddy hasn't posted the part #. Thanks again Pete
  14. #14
    Nov 2012
    Tillsonburg
    http://www.maxrules.com/fixomcwiringcodes.html
    Here are the OMC wiring codes, if you use these you can wire a female merc connector from a motor to a male connector from an omc harness to make an adaptor
  15. #15
    adaptar harness
    Quote Originally Posted by Bruce C View Post
    Thanks Bruce, If I can't find adapters I'll make them. But for $40 each it's not worth making them. STILL LOOKING FOR ADAPTER #.
