Results 106 to 120 of 159
05-29-2013, 01:37 PM #106
05-29-2013, 01:40 PM #107
05-29-2013, 02:20 PM #108
Keep it up Pete, I might just show up at the Romp with a new interior color.
1976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
"The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
05-29-2013, 02:34 PM #109
$hit you are going to be lucky to get your ass out the door with all your crap and find a place for the ole lady to ride out east.
Sunsation 32 Dominator - 496 MAG HOs
Nothing runs like a Deere when a CAT's on it's ASS!
05-29-2013, 05:25 PM #110
He will be prepared.
Team Junk
05-30-2013, 07:31 PM #1115000 RPM
- Jun 2006
- Kaplan, LA
- 153
I had the same thing happen to me several years ago. I had never determined what caused it. Prior to pulling the powerhead everything was normal but after reinstalling the powerhead I experienced what you are describing. The only thing I could come up with was that I used an aftermarket powerhead base gasket instead of the merc gasket. I truly believe if you didn't buy a genuine merc gasket that may be the problem. I don't recall the part# but I bought all my parts from a local shop and I never had a problem. On the last installation I bought them online to save a few bucks and that's when the problem started. The gaskets were made different also, the merc gasket I used in the past was always metal reinforced. The one I bought online wasn't. I don't recall if they were identical as far as matching ports, water passages, etc. Maybe something to think about.
08-14-2013, 12:08 AM #112
just gonna keep this going with my issue since I'm dealing with a 225 promax on a 2 piece plate.
before the rebuild I had good water flow out restricted t stat housings. running a poppit valve. water pressure around 10-12 wot.
I wanted to go back factory plumbing so after the rebuild I installed 143 t stats.
here's my issues.... on the hose or in the water I'm not getting any water flow out the t stats..... whether they're installed or not ( I pulled the t stats to see if I was getting water it the heads)
on the hose water pressure is 2-5lbs..... out on the water same at idle and increases with throttle.....8 pounds on plane..... up to 12-15 with throttle punches. ( haven't been over 3000rpm for more than just a punch). to me water pressure seems normal. on the hose I've pulled water pressure hose and poppit line from top of block and both have steady stream.
I have a temp gauge reading head temp just below #2 cylinder. on the hose it holds down low.... on the water up on plane it comes up to about 145-150 ish.. and cools of when I drop to an idle..
I've replaced water pump and housing.... replaced seals at top and bottom of water tube. checked all gaskets in mid and exhaust divider plate.
heads seem ti be holding water.... enough to cool but not enough to exit through t stats.
I have the tale tell fitting on top exhaust plate blocked trying to push more water up.
I've pulled popit hose off plugging top and bottom while on hose.... still no water coming outta heads.
I'm stumped.... or stupid. please help!81' HYDROSTREAM VECTOR / slightly Modified 200
08-14-2013, 06:04 AM #113
I'll assume you've checked the pump tube itself for any leaks. Install water pump base 44292A3 and only use genuine Merc stuff for the impeller and cover. What kind of gearcase setup do you have?
08-14-2013, 06:30 AM #114
if by water tube you mean copper tube.. then yes I've inspected it with new seals to and bottom. if you mean something else on gear case side then no.
I haven't replaced water pump base.
I purchased impeller and housing kit from local merc dealer. not sure on part number. gear case is from a 1991 v6 135hp. coned with Bob's cone81' HYDROSTREAM VECTOR / slightly Modified 200
08-14-2013, 08:19 AM #115
Try that base, it has a smaller bleed hole and should raise your pressure all around. Sounds like you pretty much covered everything in the powerhead, so I'd be looking at the water feed side of things.
08-14-2013, 04:15 PM #116
k changed water pump base out. left t stats out. ran on hose... still no water at idle. soon as I bump the throttle both heads pee. right now if I run t stats I d ont have a tell tale. gonna go put it in the water and see what the pressure does... with t stats in.
if everything looks good I m gonna run a tell tale from exhaust plate out the side.
I'll be back in a bit81' HYDROSTREAM VECTOR / slightly Modified 200
08-14-2013, 07:29 PM #117
well here it is.... at idle there's just a trickle out of starboard t stat. got up on plane at 3000rpm water pressure reading 8#. temp gauge comes up to 145 ish and h olds there. at this speed there's a nice flow outta t stats.
brought it up to 5000 and saw 15# on pressure gauge. look like it would of kept climbing up to WOT.
the new water pump base definitly got me more pressure.
now to figure out if or where to run a tell tale. it scares me to idle around with no water coming out.
should I drop to 132 t stats? just cruising today. temp never ran above 150.
Pete do you have a tell tale dumping out starboard side??81' HYDROSTREAM VECTOR / slightly Modified 200
08-14-2013, 08:05 PM #118
Yep, mine is all stock
08-14-2013, 08:11 PM #119
Sorry to leave you hangin' last night Cody.....I owe ya one....
Resto Thread Here
2010 Go-Pro Stuff
08-14-2013, 08:16 PM #120
