Results 16 to 30 of 159
04-23-2013, 01:46 PM #16
Have you checked the actual temp as opposed to your temp guage? I have a point and tell unit you are welcome to borrow.
RockTeam Junk
04-23-2013, 01:47 PM #17
No I haven't but once it' hits just over 140 the T-Stat dumps start pushing water.... I do need to stop in and get one of your lifting eyes before you leave fishin... just in case.
Thanks buddy!Sunsation 32 Dominator - 496 MAG HOs
Nothing runs like a Deere when a CAT's on it's ASS!
04-23-2013, 02:11 PM #18
Give me a call. Did you check for rocks?
Team Junk
04-23-2013, 02:46 PM #19
Shoulda just left the 1 piece plate in there and worked with that.
04-23-2013, 03:17 PM #20
Yeah no $hit right, Lynn?
05-03-2013, 09:44 AM #215000 RPM
- Jul 2005
- Baton Rouge, LA
- 723
- 25
Did you check to make sure you had a base gasket that has a hole in it for the poppet to dump through?
Im fighting the opposite battle. Have a 225 PM on a 1 piece plate and keep going from too high pressure to too low pressure with the changes. Trying to find a happy medium.
05-03-2013, 11:26 AM #22
No I didn't but I think (key word there) the gaskets were for a 200 2.5..... I'm so far behind right now I won't be able to get to it for another couple weeks.
05-06-2013, 08:47 PM #23
05-07-2013, 06:54 AM #24
Let us know how it does, that's technically the "wrong" base for the application. The 44292A3 is used in most all HP applications and is shared with the Mercruiser Alpha drive. That looks like a 42579A3 for a stock 200. Could be a very useful tool for "tuning" cooling systems.
05-07-2013, 07:13 AM #25
Well the adapter plates are "different" too.... 200 = 18260A2 & 18233A3 while a ProMax is 18260T5 & 18233A5........
I really hope this fixes this....Sunsation 32 Dominator - 496 MAG HOs
05-08-2013, 07:16 AM #26
Not fixed.... It's better but pressure is still almost 20psi @ 5000rpm. Temp falls below 100 after I put it on plane. Probably going to have to pull the Powerhead
05-08-2013, 07:39 AM #27Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,736
- 102
- 115
- 1556
- 514
Damn Nic, I thought for SURE you had found the root cause...... standing by for future updates.
God, Country, and Fast Boats
05-08-2013, 07:45 AM #28
Me too Chris. I've sent a note to a guy on Allison owners... he's swapping to a 260 and needs a 1pc plate and it's going on a ProMax mid. Going to try to make a trade with him so I KNOW I have the right adapter plate.
Here's some food for thought.... would the fact that I'm dumping both thermostats out the cowl make any difference? Below 143* the T-stats are out of the picture but since the tell tale is off that line and T'd into the adapter plate where poppit water is channeled I'm thinking that once the poppit opens that is where your tell tale water comes from. This probably won't change much but thinking out loud and wondering....Sunsation 32 Dominator - 496 MAG HOs
05-08-2013, 07:50 AM #29
05-08-2013, 07:51 AM #30
Probably close to that but I didn't run it up to 90... wife & kid was with me. When I had it at 90 it was buried past 50psi.
Still no water temp Pete.Sunsation 32 Dominator - 496 MAG HOs
