Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 64
  1. #46
    Jun 2008
    5 Thread(s)
    Quote Originally Posted by Trojan-man View Post
    These hulls evolved from the 24'8"x7'8" cigarette hulls. I have a 25 action marine and a cigarette Firefox 24. Same hull with some minor differences. The 23 I am not sure. It looks as though maybe they put a block in the 25 mold? I am sure somebody can provide more info.
    You are exactly right. The 23' Action was derived from the 25' Action and was the brainchild of Barney senior. We blocked off the mold of the 25' by 23" at the transom. Then, we added an additional 4 degrees of transom angle, added reduced sized lifting strakes behind the original ones closest to the keel and added a reverse chine. The intent was to make the boat faster than the 25' Action for single applications, while incorporating the bottom changes to improve the ride, out of the hole performance and on plane, slow speed cornering and maneuverability. The changes did what we had hoped and even exceeded our expectations. Picked up a significant amount of top end speed in single applications and the ride is incredible, despite the two feet shorter length.
    Love mine. It's a boat that can do it all, from river runs to Bahamas trip! As Mr. Action says, the boats run in the 80's with a Monty V-8. Would be interesting to see what a Merc 400 R would do.
    Karl
    16' Samurai 135hp Johnson sold
    16' Banshee 135hp Johnson sold
    16' Action Evinrude Strangler sold
    21' Olympia 2.6L Johnson sold
    18' Critchfield 2.6L Evinrude sold
    20' Sanger 3.6L Evinrude V8 sold
    19' Action 2.6L / 3.6L V8 Evinrude sold
    19' Action 2.7L Evinrude sold
    19' Action 3L Johnson sold
    25' Action 3.6L Evinrude V8 sold
    25' Action Twin 175hp Johnsons sold
    25' Action 4L Monty V8 sold
    18' Action 115HO E-TEC sold
    19' Action 250HO E-TEC sold
    23' Action 250HO E-TEC
    STV R/R Monty 250HO E-TEC
  2. #47
    Jun 2011
    Prt St Lucie Florida
    man that is great.. great Job! love them
    Actions
  3. #48
    What does the bottom look like on these? Is there a large pad, cut out, what? Where do they get the speed numbers from?
  4. #49
    Conroe, TX
    Great info !! I would also like to know from you gurus that have been playing with the setups on the 25s how much set back do these boats like with twin merc outboards? Also 20" or 25" shafts? Where does the prop hub like to be in relation to the running surface? I know the Action Marine guys know how to dial them in for the best top end !!
  5. #50
    Long Island N.Y.
    whats with the picture on the bottom of these posts, ???????
    21 Tuff, Mercury 300X
  6. #51
    A little young and skinny for this old man but still nice.
  7. #52
    Prince George B.C. Canada
    Quote Originally Posted by SouthernSwing View Post
    getting close
    This is the one that caught my eye??? Pretty sure ya might want to delete that toon one for sure.
  8. #53
    Jun 2008
    5 Thread(s)
    The bottom is a traditional 24 degree vee, no pad, no step. Not sure what speed numbers you are referring to, but here is a link to a Boattest.com test of my 23 Action. With 2 people, test gear, etc. it ran 63.4 MPH and best cruise was at 3500 at 3.79 MPG.
    http://www.boattest.com/review/actio...77_23-offshore
    Karl
  9. #54
    Jun 2008
    5 Thread(s)
    We typically set the 25's up with twin 20" engines with about a 15" setback. Most times a B-Bracket or an Armstrong bracket was used, something that provides flotation works well but is not required. Some were set up with twin 25" engines, but to get the best handling and speed, we found the 20" setup worked best. Single engines at about 22' - 29" of setback. Best propshaft height varies depending on what you want to do with the boat, but somewhere around level with the bottom seemed to work well for a lot of applications.
    Karl
  10. #55
    Quote Originally Posted by action1923 View Post
    "Vindicator" ?
  11. #56
    Conroe, TX
    That is exactly the information I have been looking for. Thank you very much. I have a stainless marine 27" setback with twin 25" mids. They are set too far back to me by the way it handles and balances. I have been looking into finding 20" mids for my mercs but that is proving difficult and expensive, so may go the jack plate route. I am right around 70 now, going to have Simon do some computer tweaking to see if I can hit 80 with the correct setup. Thanks again for your information. I absolutely love my 25
  12. #57
    Jun 2008
    5 Thread(s)
    "Vindicator" ?
    The "Vindicator" boat was a 25' Action with twin 20" Evinrude 225 's Vindicators, rigged with a Porta Bracket. It appeared in the 1995 Evinrude catalog. Ran good with the V-6's, but later in life was rigged with twin Monty V-8's and ran right around 100 MPH.
    Karl
  13. #58
    Was that owned by Pazos Sr.?
  14. #59
    Jun 2008
    5 Thread(s)
    No, Pazos senior had his own 25' Action, but he did purchase those motors and ran them on his boat. It also ran right around 100 MPH.
    Karl
  15. Likes AZMIDLYF liked this post
  16. #60
    Central, PA
    Great job, looks damn good man. It's great to see the step by step photos included. Enjoy
