Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
    Jun 2002
    Northern Utah
    Yamaha HPDI ECU Mods
    I have Yamaha 3.3L with Hydro Tec Phase III mods. I see that Simon Motor Sports mods Yamaha ECUs as well as other outboard ECUs. I'd like to raise the 6150 rev limiter on mine and see if there is any more performance to be gained with ignition/fuel changes.
    I have yet to see a post where someone has had their Yamaha ECU reprogrammed. Anyone had this done?
    Mar 2010
    Holly
    i am also very interested in doing this with my 3.3 as well... with the mods done to mine i am also wondering if there would be benefits changing the fuel curve... Any thoughts on this ?
    22 Talon w/ 300 HPDI
    Feb 2011
    Baxter, Mn.
    The 3.3L ecu's are extremely difficult to read. Eric Simon has spent a lot of time trying with not much success.. As far as the rev limiter is concerned he was doing some "clocking" a few years back to get them to rev to 6350 and I ran one with good results. But that involves cutting the back of the ecu apart and replacing a part.. I think once someone gets the ecu stuff figured out on the 3.3 liters they will really come alive!
    I agree if we just knew some computer geeks,to help us get in there.
    Easy there tough guy,anybody can go and make a merc go fast.
    I've always had to do things the hard way,I blame my parents,sorry to high jack your thread.
    Mar 2010
    Holly
    any one have Fuel curve Thoughts?
    Sep 2002
    Parry Sound, On
    Quote Originally Posted by Jamescole View Post
    To make an extreme HPDI you're going to need fuel management for sure..but the whole system is so complicated that messing with the fuel curves is going to need a lot input from the other end to tune the thing. Buy an OX66 if you want to make big power...fuel makes power....so your fuel savings will go out the window anyway.
    with the mods done to yours changing your fuel curve won't get you far..considering its basically a 300...you could always try a 300 ECM and see if you pick up any rpm...
    Or...how about a 3.3L OX? Up the displacement and lose the two power sucking fuel pumps...
    '08 SRV
    Yamaha 3.1 Phase III
    Mar 2010
    Holly
    Quote Originally Posted by DoktorC View Post
    i think fuel management will make power with out any porting.
    Sep 2002
    Parry Sound, On
    It absolutely could...but you'll have to add something to the equation (more than you have now) whether it be compression, porting, magic...to see APPRECIABLE gains.
    Hydro-tec has made more power out of the HPDI than you have in your motor...with the stock box...which tells us it's not starving for fuel until it gets to wherever they got to with the motor. If you're talking about adding a HP here or there buy finitely tweaking the fuel curve to run on premium..than yes there are probably some maginal gains to be had BUT given how HT operates and the HPDI system is an open loop I would say that there is enough fuel there to make whatever they can make with the phase III...or 4 or 5 whatever they call the ported/high compression version of your motor. Just remember...Lean is mean...and that motor is expensive to tune by plug chops and EGTs...
    That being said you could just have it ported and pump the compression (the next phase...22?) and add more power for less money....then start thinking about fuel curves, timing, and rev limiters...
    '08 SRV
    Mar 2010
    Holly
    so.... Fuel management is useless?
  12. #12
    Sep 2002
    Parry Sound, On
    On your motor? The way it sits...I don't see it as the most cost effective way of gaining power. Don't put words in my mouth...
    '08 SRV
  13. #13
    Mar 2010
    Holly
    do you think if i bump my limiter there will be more HP in the 6500 range?
  14. #14
    Sep 2002
    Parry Sound, On
    Not without porting...The 300 is ported differently and even it has the same limiter. You're nowhere near running out of available prop pitch so I wouldn't really worry too much until you break 93...
    '08 SRV
  15. #15
    Jun 2002
    Northern Utah
    Regarding Dentguy's post, the Simon Motorsports website states they can raise rev limiters and do custom tuning on most Yamaha Outboard ECU's 2003 & UP HPDI 200, 225, 250, 300, so they certainly imply they have the computer figured out. I guess I'll call them and see what service they provide. BTW Keith, the Yamaha I bought from you 2 years ago is still running great!
    I seem to remember seeing several posts on a Hydro Tec dyno test where a 3.3 HPDI, ported, phase III, had the rev limiter raised and the horsepower kept going up well past the stock 6150 limit. I don't remember the specifics.
    Another thought... the ECU takes inputs from several sensors including atmospheric pressure and air intake temp. I wonder if the electrical signals from these sensors could be changed slightly and therefore change the fuel curve? For example have the air intake temp tell the ECU it is actually at a lower temp and therefore more fuel would be added. I'm assuming the ECU works something like that?
