Results 1 to 15 of 18
    Jun 2009
    ohio
    How yo identify a mercury 200hp
    I am going to look at a mercury 200hp . I am very familiar with the mercury 150 hp, this is a late 80s model by the way . What is the easiest way to determine it is a 200 hp and not a 150 or 175 with 200 hp decals . ? Not that i dont trust the guy , just want to make sure .
    May 2008
    Walker, LA via H Katrina
    Look for a gray soft plug on top of the motor, with stamped numbers and letters. Provided you reserch a web site that gives you year and hp data. Copy and paste this data, print, and carry it with you. At the moment, you can try www.maxrules.com for this data.
    luckybuff
    Jun 2009
    ohio
    ok i know the 150 has the black cap and yellow on top of flywheel , so the 200 used a gray one.?
    Jul 2002
    FT WORTH, TEXAS
    CAP? YELLOW ? that means nothing on that vintage of 150 unless its a xr4 is a 2.0 ,a 200 is a 2.4!!!!! due to its age there could be a number or "IDEAS'' that could make it hard to identify pull the head measure the bore should be 3 3/8 if a 200, there is a build date stamped on the throttle side of the motor up near the connection of the trigger to the throttle arm or at the base of number 2 cylinder "that helps with the "late 80's year model" 2 pc heads or lost foam ??
    Bensalem, PA
    my late 80s 200 has the numbers stamped on the block on the port side. think it is either under the flywheel or where the front half meets the block.
    TX......somewhere?
    This just applies to an unmolested motor which might be a stretch.
    '89 and older will have horizontal front half/reeds and have tha air box that look like a "pipe organ". '89 was also tha year tha newer style air box came out so it could be different. If it has tha newer style it could possibly be tha XR4 150 (or '89 175 efi converted ta carbs). Thats tha year it went to horizontal reeds . Also tha year tha clam shell went away. '88 and older will be tha clam shell. First sign of a 200 with clamshell is it will have only one "plastic" interlocking latch. if it has two of tha metal, spring type its not a 200. '89 was a a year of some change. No numbers on tha block, it might be a challenge ta get it right. '88 back is not a problem pickin' one out........... Provided it hasn't been "butchered"..........
    JAN. Tha "cap" they are talkin' about is a welch plug. Looks like a freeze plug on top of tha block right behind tha flywheel. Some have a serial number stamped in 'em. Some will just have "200" stamped in 'em. Some won't have anything stamped in 'em......................
    Jul 2002
    FT WORTH, TEXAS
    Tommy thats why i said "other ideas" its a rare thing indeed to find a untouched 2.4 200 or any V6 mercury that old these days after all its almost a quarter of a century old and lots of hot rodders around build dates are where i specified on just about all motas except replacement powerheads serial numbers are where Tommy said "somtimes"
    TX......somewhere?
    Bobby, sent ya an email...........
    Jun 2009
    ohio
    ok i got some numbers maybe someone can help me it s suppose to be an 89, 6532173 on the plate and 8586482 on powerhead .,
    Jul 2002
    FT WORTH, TEXAS
    those are not the build date it will be xx month xx day xx year ALL of them that are stamped 1/8 tall hand stamped block half bottom of number 2
    Jul 2002
    FT WORTH, TEXAS
    do you know the difference between vertical and horizontal front half ??
  12. #12
    Jun 2009
    ohio
    i guess the answer is no im not sure of the differance .
  13. #13
    Jun 2009
    ohio
    does anyone have a pic of the horizontal and the vertical front half so i know what im looking at when i go see this motor? how can i tell without tearing it apart. im guessing here if it has the horizontal its probably a 200 . ?
  14. #14
    Jul 2002
    FT WORTH, TEXAS
    yes its certain
  15. #15
    Jul 2002
    FT WORTH, TEXAS
    if your planing on keeping in the merc v6 business it would be wise to buy a manual it oh so helpful
