Results 1 to 14 of 14
    Feb 2007
    Western Washington State
    How to bring back metal flake
    I have a boat that has metal flake accents, most of that is red, some smaller pinstripes in charcoal grey, and light grey, but the majority of the hull is white. The red is particularly oxidized now. I was thinking of hitting those spots with wet 800 grit paper attached to an orbital palm sander, followed by cutting compound on wool pad, and if needed, polishing compound on a foam pad. Follow this with a couple of coast of carnuba wax. Will this work?
    Do some test spots first, you might not have to be that aggresive. Preserve the clear gel as much as possible.
    North Branch & Pine City, Mn.
    I like McGuires ultimate polish. If the gel is dull, it's porous as well. I have found that waxes sometimes actually dull or cloud the surface because it. "clogs the pores".
    If it it real chalky, hitting it with 3M super duty rubbing compound first will knock it out real quick, and the finish with the McGuires.
    The biggest thing is to protect it from the sun after you spend the time working the gel out again. I kicked my Viper's metalflake gel out and it still looks perfect a year later, but it has been stored inside since.
    The Reverend, (Cedar Machine Service on Facebook)
    1989 HST 2.5 260 Merc Offshore
    1991 Vaserette YT 200 Mercury
    1988 Venus XT 200 Yamaha
    1983 Viper II Merc 90
    1977 Viper
    Mini GT tunnel, 25 Merc
    "African Queen" pontoon 25 Merc
    Aluma fishin tub, 20 motors to choose from!
    GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
    Apr 2006
    Viera (Melbourne), FL.
    If the gel is down to the edges of the metal flakes it will oxidize again in short order. My first boat was a Glastron GT150 with silver flakes and I got sick of constantly having to compound the thing so I shot it with a PPG Concept clear urethane. Never faded again.
    Nov 2003
    McHenry,IL
    Regardless of compound. When you have no clear the flakes surface and then no matter the color turn silver because it is metal flake ,anodized aluminum in most cases.
    Try one spot with aggressive compound if it works you should be ok if it turns silver well it may be to late.
    1000,1500,2000 then a light cold buff not heating the clear up cause it is softer then colored gel. Colored gel has pigments and more solids. This is why clear bakes off easier in the sun.
    www.bottomsupboatrepair.com
    847-
    587-5553
    Complete Service Center
    Sep 2010
    quebec
    I'm buffing out my stv. I used with wool pad 3M super duty and with foam pad 3M finess it and mcguires #9 swirl remouver and it does the job I spin my buffer at the slowest speed of 600 rmp and wet my pad and surface of the boat. At some place you might have to do the ruff compound step twice if it's badly oxidize but otherwize it worked out good for me.
    At the end I used colinite 885 wax since it has only 2% silicone in it.
    2000 STV pro comp with drag bottom
    with 260 merc 1992
    Feb 2007
    Thanks for all the great replies. When the weather here improves I'm going to have to give it a try.
    Sep 2002
    If you choose to wet-sand, start with the finest grits like 1500 or 2000, and only move to a coarser grit if the finer grit isn't cutting enough. Take the least invasive approach necessary to get the job done.
    I also want to thank croSSed and everyone else for the input since I am also in the process of buffing a flake boat (84 Calson CVX-17). Gary
    Feb 2007
    Alright, here's what I ended up doing. I orbital palm sanded the metal flake parts with 1500 grit wet sand paper, then hit the whole boat with Production Car Care Products Synthetic Cutting Creme with a wool buffing pad, and followed that with 303's Aerospace Protectant, and here's what it looks like now. I will say that I should probably hit the gel coat again with a finishing creme, like 3M Perfect It and a foam pad to get all the swirls out, but you can't see the swirls unless the light is just right. Also, the 303 Aerospace Protectant should be a regular wipe-down regimen now, but I think it looks really good. You get an idea how beautiful these old metal flake boats were new in the showroom after doing some work like this.
    Attached Thumbnails Attached Thumbnails P1010556.jpg   P1010557.jpg   P1010558.jpg   P1010559.jpg
    Nice! croSSed Have been working on my cvx17 but I have come to the conclusion that it may have gone too far. The aluminum flake has been exposed before I obtained boat. After lightly wet sanding and buffing it just is a shiney silver--where it was red! May have to paint this winter. Thanks for the info Gary
  12. #12
    Nov 2003
    Portsmouth VA
    We used to scuff the deck with 180 or 220 dry, blow it down, prep sol, tack rag, and a wet coat of clear Imron. Worked great on weathered decks. To get an idea of how it will look, flow a water hose over the deck.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  13. #13
    Dec 2011
    Ludington michigan,on the shore
    Just did a old switzer last week,hand wet with 1000 then 1500 till smooth, and slick.It was a gold flake and it did get into some of the flake,you can tell cause it turns silver.shot over with three coats clear coat.Hand sand with 1500 and buff.Looks as good as new, except for some silver flake mixed with the gold.
  14. #14
    Jul 2011
    Peterborough, On
    http://youtu.be/uVlNUljCK1A
    My metal flake is coming through. Last winter was rough on my boat, I had to get aggressive with it. Since this video I finished buffing it, buffed again with foam pad and meguiars one step, then waxed with turtle wax liquid ice. To look at it and feel it now you'd never know the flake is exposed.
