Results 1 to 6 of 6
Thread: 75 hp optimax low air?
02-06-2013, 12:36 PM #15000 RPM
- Mar 2002
- Wetumpka,Al.
- 293
Motor runs rough and stalls at idle. I can't keep it running any lower than 2000 rpm. Firing on all three, and just cleaned fuel system.
What kind of air pressure should I get from the compressor on my 75 Opti. and what is the best way to test It ? Also what should the fuel pressure be? Any info. is greatly appreciated.
Thanks
02-06-2013, 02:48 PM #2
90 air 105 fuel.. This is plus or minus 2-3 lbs.. If air is out of spec, pinch off the dump coming off the rail and see if air spikes to 120. If it will not u may have a bad a/c. Remove cover an inspect piston and reeds .. I had a similar issue come in.. Customer did his own service and ended up putting the wrong spark plugs in it..
02-06-2013, 05:20 PM #35000 RPM
- Mar 2002
- Wetumpka,Al.
- 293
If it spikes to 120 with pinched off line what then?
02-07-2013, 03:16 PM #45000 RPM
- Mar 2002
- Wetumpka,Al.
- 293
You hit the nail on the head. After fixing fuel pressure problem (ethenol eat pump grommet) the motor still ran like crap. I then discovered that the spark plugs the parts Guru gave me were autolite crossovers and not the original NGK's. I put the old plugs back in and it runs fine. "why you got to be so sensitive" Freekin Optimax! LOL! Also don't understand why their asking for 21 dollars a plug.
02-07-2013, 06:24 PM #5
02-08-2013, 02:15 PM #65000 RPM
- Mar 2002
- Wetumpka,Al.
- 293
will do
Thanks
