Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 64
Thread: Turbo TXP props
  1. #46
    Mar 2013
    Sunshine Coast, Queensland
    Thanks Steve. Do the TXPs come in 22, they only appear as 21 and 23 on the website?
  2. #47
    Sep 2011
    Quitman, TEXAS
    i don't think so. for some reason they skip the 22p in the txp
    but the lightening is made in a 22p. i'm not a huge fan of the lightening prop. but it does
    work on some boat/engine combo's .. mostly the older engines.
    98 XR2001 Drag w/pro stock mota
  3. #48
    Sep 2010
    long island,ny
    I have experimented with the TXP and the lightning and seems if your boat likes alittle more stern lift then you will like a turbo Lightning. JMO
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  4. #49
    Jul 2004
    Connecticut
    How does the Turbo TXP compare with the Turbo Fusion 4?
  5. #50
    Sep 2011
    Quitman, TEXAS
    i played with modifying the fusion 4's and never even came close to making that prop run good.
  6. #51
    is that true that the raker mk2 is made by solas in malaysia ?
    if so that's put me right off a mk2
    phill
  7. #52
    Sep 2011
    Quitman, TEXAS
    from my understanding BRP is having Solas make all there props now. and yes, they are made in malaysia.
    if your looking for a raker (or close too) blade design. then the power tech RK3 or the turbo txp are
    the two closest blades to that design.
  8. Thanks dnelson964 thanked for this post
  9. #53
    have any of these props got a bit more rake than a raker ?
    phill
  10. #54
    Sep 2011
    Quitman, TEXAS
    the Raker II has alot of parabolic rake in it. it has too because of the soft metal.
    more rake? i would say no.(about the same) but they do have more progression and higher cup heights than the original raker, but not
    as much as the raker II.
  11. #55
    I am pretty limited I think to the make of props due to size of gearbox, mine is the omc triple with 2.42 reduction and I think about 4 1/4 hub with the 13 splines same size as the old v4 140 gearbox.
    I am trying to find what will give the most bow lift possible, my boat runs too wet. I
    I have tried a silver streak/srx but that dont get the front out the water enough. not much different to a sst to be honest.
    phill
  12. #56
    Dec 2012
    HUDSON, FLORIDA
    am i the only 1 who has tryed a scorpion prop talk about lift incredible !
    Quote Originally Posted by steve@scp View Post
    i bought a few of the fusion to see if they were similar to the rev4 by merc. NOT EVEN CLOSE!!!
    i wholesaled the fusion's and never bought another one.
    p.s. what i was trying to find was a prop that would compare to a rev4 or bravo I. haven't found one yet, other than a hydromotive.
    Hill Marines bravo style prop is okay, but needed alot of work to run with a bravo I. Hering's B1 4 blade is killer! i gave them some specs
    for one i wanted and it's fast!!!! and virtually will never break... but it's 1550.00!! ouch. simply the prettiest prop i've ever seen.
    has 15.2 dia. and claim 40'rake i run it high with only small torque compared to a chopper no nose cone boat loved it. now with 2.4 220 mag with cone runs 75 but i think the bobs lower is slowing me down feels heavy even thhough i gained 8-10 mph from the 150 the 220 came with coned lower really wanted stock 1.87 needto trade for a stock good 1 87 CLE too much $
  13. #57
    Dec 2012
    HUDSON, FLORIDA
    i saw a post about a 21 super boat plain v hull ran a scorpion and said best prop ever just had to drill larger pvs holes. i had to do the same they have as claimed parabolic rake huge cup i heard there made in NEW ZEALAND
  14. #58
    Sep 2011
    Quitman, TEXAS
    i may not have been running it high enough... good info.
  15. #59
    Sep 2011
    Quitman, TEXAS
    Quote Originally Posted by phillnjack View Post
    phill
    give power tech a call. they may be able to help you. 1-800-736-7767 or shoot them an email.
  16. #60
    Helsinki, Finland
    the tempest is a great prop.
    the txp's run very similar. i do alot of testing between the two.
    matter of fact i just ran a z8 nitro with a 225 pro xs. the 26p tempest ran better than a 25 or 26 txp
    just depends on what the boat wants.
    Steve or anyone with experience on the TXP's.
    The best prop on our race boat with a 150 ProXS has been a 29" Tempest Plus at around 5800rpm. However, the Tempest is slightly short. As Merc doesn't make Tempest in 30" I was planning on testing the TXP 3. Can you give me some pointers on whether to go with 29" or 30" TXP 3? I've heard the TXP is rather stiff... We've just briefly tested a 30" TXP OT4 and that lost quite a bit of revs compared to the Tempest 29", but was still about as fast.
