Results 1 to 15 of 16
Thread: Bypassing the VRO
01-10-2013, 06:23 PM #15000 RPM
- Sep 2009
- NE Ohio
- 112
Bypassing the VRO
I've got a 1985 Evinrude 140HP looper, and I have heard that the VRO system uses a common shaft for the fuel and oil pumps. The plugging off of the oil lines and input would starve the shaft of lubrication, and over time, the pump would then fail. That said, the recommendation was to go to a fuel pump that is ONLY for fuel, as from a pre-mix/non-VRO motor.
Is this a valid concern, because I hear a lot of guys just plug off the oil-lines and run pre-mix?
thanks
01-10-2013, 08:46 PM #2
No shaft. It works from an air pulse to a diaphragm in the pump via a hose from the crankcase to the pump. Plug the oil line, premix, and you're good to go.
01-10-2013, 09:11 PM #35000 RPM
- Sep 2009
- NE Ohio
- 112
01-10-2013, 09:34 PM #4
Evinrude makes a fuel only pump for v-4 and smaller loopers/crossflows. There are a bunch on ebay. Would be a simple hassle free pump to get rid of the VRO.
Although, I ran a VRO fuel pump with the oil side disconnected for years without an issue. Whatever suits you best.
01-10-2013, 09:38 PM #55000 RPM
- Sep 2009
- NE Ohio
- 112
Yeah; I did the removal and install of a straight pulse pump on my 90HP Evinrude, which had the port and bolt bosses on the block. I'll have to look at this looper (the 140HP) and see if it has the same port available to do that. I will run it with the VRO minus the oil input and see how it goes.
thanks
01-10-2013, 11:05 PM #6Member
- May 2006
- Houston, Tx
- 90
Just one thing after disconnecting the VRO and adding oil to the fuel, disconnect the fuel hose from the VRO and pump fuel to thru the hose untill you get premixed fuel to the pump so you dont run a fuel hose full of un-oiled fuel thru your motor.
01-11-2013, 10:02 AM #7
or do the smart thing and leave the vro on to do what it is built to do. less oil at low rpms so you have a much cleaner and smoother running motor. when rpms increase so does oil ratio. omc is not like older mercs with a plastic gear driven pump that fails. if your pump on omc is getting a pulse signal you have gas and oil as long as you keep oil in the tank there is not a problem.
01-11-2013, 04:43 PM #8
If you plug the oil hose and disconect the electrical plug on the vro pump it work just fine. I have done this on a 100 something engines, it is also possible to rebuild it and ot will work for 10 years
When it comes to propellers, I hate Choppers!
-Sunwind 480 race boat 90 omc- Sold
-Tintopieta 20 race boat with 90 yam-Sold
-B-19 batboat with 90 yam-Sold
-B-23 batboat with Merc 200xs-Sold
-B-28 Batboat 662 merc sci- Present
-Twister 24 Special edition Merc 200XS ROS - Present
-Twister 24 Merc 200XS ROS - Present
01-12-2013, 01:09 AM #9
01-12-2013, 07:02 AM #10
Hey fellas I never thought and dont think I have seen it asked or answered.....when replacing the VRO with a straight fuel pump....my crossflow had a 3 line VRO on it but does have the fuel pump bosses on it. Is it better to change out to the 3 line fuel pump or can you just switch it out for the 2 line pump and not have to switch any pulse hoses around.
Laser 1550 ...under construction with a serious weight loss
Motor 2.4....undecided on hp yet
01-15-2013, 09:56 AM #11
01-15-2013, 05:33 PM #12
You could go with a Carter electric pump with great results. Don't have to worry about stock pump problems. Cheaper too!
01-16-2013, 05:46 AM #13Laser 1550 ...under construction with a serious weight loss
01-16-2013, 04:23 PM #14
01-18-2013, 05:18 PM #15Member
- Jan 2009
- Wisconsin
- 50
I've run VRO's as long as I've been boating and really haven't had a problem. If it works, I'd keep it as mentioned above.
Regarding damage to the pump after running without oil, I've taken apart pumps that have run with the oil side dry. Typically the oil side is not in good condition. I would not try to use the oil side of a pump that has been run dry.
