Page 179 of 182 FirstFirst ... 79 129 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 LastLast
Results 2,671 to 2,685 of 2728
  1. #2671
    Jul 2004
    Connecticut
    B
    ecause 2018 has arrived, and "The List" still tells no lies............
    Fastest SOB Hulls Available For Purchase New In 2018....All Boats Powered with a stock Mercury 300XS (306HP and 6400RPM Limiter)
    #1 Tuff 21 kevlar hull-890lbs – 20’8” Long, 7’7” Beam - 22 degree deadrise + 7 1/2" pad
    Confirmed 105.9MPH Driver
    Blake Sewell Canada
    #2 Bernico F2 21 standard hull-727lbs–21’4” Long, 6’3” Beam - 24 degree deadrise + 14” pad -- Confirmed 98.1MPH Driver Dave Van Steelant (550lb s3000 385hp 103.1)
    #3 Progression 22 standard hull-948lbs – 22’1”Long, 7’8” Beam - 24 degree variable deadrise + 7" pad -- Confirmed 94MPH Driver goneby
    #4 Sutphen 21 standard hull-1325lbs–20’9” Long, 7’2”Beam - 20 degree variable deadrise + 3" pad -- Assumed 88MPH Driver Unknown (525 I/O heavy layup ran GPS 93.4)
    #5 Nordic Crossfire 21 & SR-21 standard hull-1475lbs – 21’ Long, 7’1” Beam - 18 degree deadrise + 9" pad -- Confirmed 86MPH Driver wildone
    And the fastest of the no longer produced hulls....with power noted below
    #1 2002 Intimidator 21 -- Deadrise=22 Degrees + 6" pad. Confirmed 100MPH – Stock Merc 15” 300X(325HP) - Driver Trimmed Out15
    #2 1986 Superboat 21 Classic -- Deadrise=22 Degrees + 6" pad. Confirmed 97MPH - Stock Merc 20” 300X(325HP)- Driver hoser
    #3 1985 Velocity 22 Stepp -- “Old Style Deck” Deadrise=22 Degrees + 12" pad. Confirmed 95MPH – Stock Merc 300X(325HP)- Driver B kNo023
    #4 1976 Challenger 21 -- Hull 1350lbs Deadrise=21.5 Degrees. Confirmed 90MPH - Yamaha 250HPDI Phase III (326HP) - Driver Jamescole
    #5 2012 Velocity US 220 -- Hull-1895lbs – 21’6” Long, 7’11” Beam - 22 degree deadrise + 12" pad. Confirmed 84.8MPH – Merc 300XS - Driver aaronmt73
    #6 1990 Activator 21 -- Hull 1475lbs Deadrise=22 Degrees + 5 1/2" pad. Confirmed 84MPH – Stock Yamaha250 Ox66 (256HP) - Driver dnelson964
ID:	396333   Click image for larger version.
  2. #2672
    Just saw that Predator Powerboats purchased the Intimidator molds and will be building some 21s that might break onto this list.
    The best way to predict the future is to invent it...
  3. Likes noli, Trimmed Out15, tux974 liked this post
  4. #2673
    Jul 2004
    Connecticut
    Outstanding news, the 6th slot is open and waiting in 2018
  5. #2674
    Boat pictured ran right at 100 with the X so an XS should not be too far off.
  6. Likes Greg G liked this post
  7. #2675
    Jul 2004
    Connecticut
    Build it and they will come
  8. #2676
    Funny, the European hulls are generally much narrower than the U.S. versions. The Bernicos, Phantoms, Chaudrons, Graunners, etc, run small beams.
  9. Likes powerabout liked this post
  10. #2677
    I agree and the construction methods will be improved on from past methods as well.
  11. #2678
    Feb 2005
    Toronto Canada
    The Tuff 24 is narrower too, I also expect it to be at the top of this list this year by a significant margin
    RIP RPM RACING
    RIP Galen Burden
    2011 ODBA PRO DRAG world Champions
    Triad River Rocket
  12. Likes tux974 liked this post
  13. #2679
    Quote Originally Posted by RBT View Post
    I agree on both points.
  14. #2680
    Jul 2004
    Connecticut
    The new Nitra 22 footer from Sweden uses a super narrow 5' 7" beam and clocked 78mph when tested with a 200hp G2.
ID:	396349   Click image for larger version.
  15. #2681
    Jul 2004
    Connecticut
    I'm not sure what a 200 and 78mph would translate into with a stock 300XS and Sporty but always good to see new innovations in a rough water SOB.
    https://www.youtube.com/watch?v=EF1rI4mqFJ8
    https://www.youtube.com/watch?v=pvz5bVMPO4s
    Second video rough translation, it's 26 degrees out and I'm running my Nitra
  16. #2682
    Jul 2004
    Connecticut
    The Swedes are not afraid to pack a lot into a little.
    https://www.youtube.com/watch?v=UeWx_Zgpkv8&t=5s
  17. #2683
    Suffern, NY
    Hey Greg your list needs updating. Bens boat has a confirmed 97.1 this fall. As I see it his boat should be # 2 on that list.
  18. #2684
    Brought my 1992 Superboat to Florida this winter with every intention of making it on the list sometime between now and April
  19. #2685
    Singapore/Melbourne
    Hot humid air....
    Wont go as fast as it does up north
