Page 7 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 91 to 105 of 292
  1. #91
    Mar 2011
    Virginia
    The location also determines the pressure difference and direction of flow during operation. If the drain hole is to the inlet plenum, water flows to the cylinder area. When the drain is to the discharge plenum, water flows out of the cylinder area when running.
    Go Time
    26 Regulator twin 250 EFI
  2. Likes Greg G liked this post
  3. #92
    Jul 2004
    Connecticut
    Go Time, did you get the OEM Promax 15" Tuner that you show on the right of your photo below as NOS somehow? What is the part number stamped into the casting?
  4. #93
    Mar 2011
    Virginia
    Greg, I got it from Lee....dont you remember, you said it was like finding a needle in a haystack ��, the next thing you know, Lee hooks me up. Last I checked, they were still available $400.
    Go Time
  5. #94
    Jul 2004
    Connecticut
    Interesting bit of info from a post years ago .......
    Quote Originally Posted by steve View Post
    In early 1995 there was a rectangular tuner version that Merc made that had a 3/4" water tube and the tuner was a longer, thicker casting and different shape then the 1993-94 260. It was only made that one year though, then they went to the oval. That one version rectangular with the big water tube also uses the stronger bolt pattern then the earlier rectangular ones and accepts the earlier tuners as well as the one it came with (dual bolt pattern). The SST120 came with a variety of 1pc adaptors as well, and they can be adapted to run on a 2.4 or 2.5 with the larger exhaust outlets. The Promax 225 Offshore and 15" SS also came with an unusual oval tuner some years. It is narrower and shorter then the 260 tuners. And the Promax 200 SS came with the SST120 size openings in its 1pc.
  6. Thanks texasvector thanked for this post
    Likes texasvector liked this post
  7. #95
    Jul 2004
    Connecticut
    Quote Originally Posted by Magcat 62 View Post
    I DID THE marles set up fender washers poppet hose to fine tune running old school 15'' 1 pc &2.5 steel bore havent tryed it yet 1pc has small holes to cool w/pump hope it heats up like 125 or so .
    The Marles conversion approach is proven but there is a big missing link to it. It's really not designed for cool Northern water temp zones never mind 12 month running in those type of waters. Here in the Northeast I can run 10 months of the year easy. I normally take a Christmas Eve spin in fact but today it's raining. Our water temps in Long Island Sound to Rikers Island will swing 30 degrees over a 12 month year. There is no way you can manage to that and keep your engine alive without T-stats and Poppet. Now, if you are in Texas or Florida it might be a different story but you better check your temp swings in the zone you boat in or your steel bore motor WILL have something to tell you.
  8. #96
    Aug 2012
    beaumont, tx
    we make adjustments throughout the year....
    good info on this thread greg.....
  9. #97
    Dec 2011
    Ottawa
    I think I have one of those plates/tuners here,3/4"water tube
  10. #98
    Dec 2011
    Ottawa
    this came in a 94/95 260 with ridgeback sporty and 3/4" water tube.the one on the right is a 2.4 BP unit
  11. #99
    Dec 2011
    Ottawa
    this one came out of a 93 260 with a bass mid.
  12. #100
    Mar 2011
    Virginia
    Here is the modified one pc with poppet discharge chamber and drain holes welded up and reduced to 1/8 inch
    Go Time
  13. #101
    That looks like it will work quite well
    Mar 2011
    Virginia
    Yeah, now I can use the good tuner and have good temerature control all year with less tweaking needed. I will post this spring when the engine is fully assembled and running.
    Go Time
  15. #103
    Belgium
    Hi,
    Do you need any other mods on the block done for water drains etc? I would like to do this on my 2.5 200. So can i Just swap the 2 pièce plate by this plate and done?
    The adapter I have is different. It's off a Bp. Is this ok too?
    Thanks
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  16. #104
    Mar 2011
    Virginia
    The modifcations made to the one piece adapter like above should allow the powerhead cooling system to work (and drain) in its normal configuration other than the telltale discharge, which now comes directly off the thermostat discharge.
    Go Time
  17. #105
    Jul 2004
    Connecticut
    A random bit of info I stumbled on..............
    I had a Promax with a 1 piece plate and later went to a 260. The promax plate definately had smaller exhaust openings, the water dump holes were a lot smaller, and it had smaller studs that mounted to the swing arm. The studs for the tuner mount were the same as the 260 so any 2.5 tuner should mount up.
    Shaun
    2012
