Results 46 to 60 of 292
12-06-2016, 11:42 AM #46
12-07-2016, 01:50 PM #47
I will be lifting a modified 2.5 150 power head off a 2.4 1 piece exhaust plate soon. I can post some pics of what we did to be able to use popet valve and thermostat cooling( standard steel bore engine cooling) It's quite simple . I am surprised at the number of posts that show up on this site that say you can't use a one piece plate with thermostat cooling.
Popey
David - WI thanked for this post
12-07-2016, 02:29 PM #48
12-07-2016, 06:02 PM #49
All the mods are in the plate, block is stock. You can mount any poppet valve small block powerhead to the plate except the early pre 80s with the kidney shaped exhaust.
Popey
12-07-2016, 06:24 PM #50
Then you would have to create a poppet cavity in the plate.
12-08-2016, 12:10 AM #51
Yes, create a popet cavity with a water dump passage straight out the bottom. Plug up the existing water drain holes and drill 2x 1/8" drain holes to allow powerhead to completely drain.
Popey
bigboy, David - WI liked this post
12-08-2016, 03:14 AM #52
12-08-2016, 06:49 AM #53
tux974 liked this post
12-08-2016, 03:08 PM #54
There is another way to use a popet and thermostat on a one piece plate. If you are using a lightweight or performance cowl pan, weld plugs in 4 of the base plate holes, the ones that let water out of the powerhead and into the exhaust plate. This way the water has to pass through the poppet in the block. You do not need to modify anything else.
Popey
12-08-2016, 05:53 PM #55
12-08-2016, 06:11 PM #56
Thanks Steve
Would like to see some pics of the modified adapter.
I always thought it was not good to mount a 2.5 on a 2.4 adapter. Other way should be no problem.
Did you have to modify the exhaust in the adapter? 2.4bp should be bigger than the 2.5 fishing block?
Thanks
12-08-2016, 06:59 PM #57
The modified base plate does work but modifying the exhaust plate is better. I have never fitted a stock powerhead to a one piece plate, they have always been modified in some way and always had the exhaust openings opened up to match the exhaust plate.
Popey
12-08-2016, 07:03 PM #58
Sorry, forgot to mention that will be about a week before I get the powerhead off and pics posted. Cheers
Popey
12-10-2016, 10:35 AM #59Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
12-10-2016, 12:16 PM #60Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
