Results 1 to 5 of 5
    Jul 2012
    magnolia tx
    78 150 max water leak on #6
    looked thru post and could not find. new head gaskets milled heads all sufaces good but a bad leak on #6 can this be gaskets under power head any one had this problem i am torqueing to 22 pounds and on leaks on other cylinders just cant quit now any thing will help.
    22lb/ft is not enough, spec is 30lbs, are the block surfaces true? Exhaust dividers can leak but would think there would some water in other cyl's.
    Dec 2011
    Ludington michigan,on the shore
    The early exhaust dividers were a problem for cracking, If the crack is near the bottom it may be spraying water into the #6 ex port only.
    charlotte,nc
    I just repaired one with the same symptoms.
    Bad power head gasket letting water through.
    death is certain; life is not
    Jul 2012
    magnolia tx
    thanks guys have to get a lift ring and gaskets and probly sum pig puddy but i am hooked the thing sounds so good and vrevvves like crazy!!! can not wait to get it right.
