Results 1 to 6 of 6
Thread: Old V4 Swivel bracket swap?
10-23-2012, 08:49 PM #1Junior Member
- Feb 2003
- Chicago
- 13
I have a 1972 Johnson 100 HP motor on my MX-15 that runs great.
I'd like to swap the swivel bracket from a newer motor to gain the tilt tube steering and power trim.
What year and HP motor swivel bracket would interchange?
10-23-2012, 09:12 PM #25000 RPM
- Feb 2012
- Canada
- 346
You would be able to fit most modern clamp brackets(v4 or v6) to your outboard with a little work.
You would have to make of find the upper bushing and use your orig. lower swivel bracket (the v shaped thing with the big nut holding the swivel tube)and swivel tube.
Try a search on "The shiny motor" this guy has done exactly what you are trying to do.Last edited by evilrude 1; 10-27-2012 at 08:36 PM.
10-27-2012, 10:43 AM #3
here are the dimensions I came up with
upper, id=1.325, od=2.00 hieght=1.25
lower, id=1.325, od=1.50, don't remember what the height is.
The lower I was able to purchase at a local bearing supplier.
first pic shows new made bushing, trim unit upper, 1973 upper
Paul V.
1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
10-29-2012, 08:39 PM #4Junior Member
- Feb 2003
- Chicago
- 13
Paul,
The "Shiny Motor" looks great. How did you polish it like that? How long does it stay shiny? Does it have clear coat?
I'm wondering what I should look for. Are the newer pivot shaft/swivel dimensions the same? Can I buy any swivel and adapt it with bushings? Are V4 and V6 the same?
10-29-2012, 10:05 PM #5
Hey, if you'd be interested I've still got the midsection from a '90 Johnson 200 I parted out. It doesn't have the tilt/trim system, I sold that separately, but everything is there. You should be able to pick up the tilt/trim unit on ebay for around $200.
1979 Checkmate Eluder
rebuild thread http://forums.iboats.com/boat-restor...er-541058.html
1993 Rude 175
1990 Johnson 200 - died
Where NOT to buy an engine in Savannah, GA http://forums.iboats.com/showthread.php?t=537238
10-30-2012, 10:49 AM #6
The paint was stripped with aircraft paint stripper, then sanded alot, then polished with a grinder with polishing wheel.
It was not cleared, I only used the motor one year, and I just dried it when done each time out. It is still shiny probably 6 years later.
I think the v4 and v6 are the same but I am not positive. I used one I had from a 1978 140.
Good luck with your project.
Paul V.
