Results 91 to 105 of 115
07-10-2017, 11:31 AM #91The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
Two rights don't make a wrong......what was the cause of the overheat? Nice rig.
wogi liked this post
07-10-2017, 12:44 PM #92Member
- Oct 2007
- 88
- 10
- 31
- 48
Impatience and just plain being stupid. Sucking air into water intakes on the non XS lower unit.
1964 Chris Craft Holiday
Homemade Glen-l Crackerbox
71 Switzer 17 with twin Merc 1350s
07-10-2017, 12:51 PM #93The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
What will you be doing to correct the issue? Tie-bar adjusted straight ahead, or toed one way or the other?
07-10-2017, 12:57 PM #94Member
- Oct 2007
- 88
- 10
- 31
- 48
They are straight ahead, looks odd from the angle is all. Plugged the top 4 holes and opened up the area between the bottom 3, then fashioned up some scoop type plates similar to the overpriced Mercury ones and bolt thru the 4th hole from the bottom. If I can't hold WP after that I am going to plumb a transom mounted pick-up into the flush port on the side of the gearcase as a last resort. Really just need another XS lower at a price I can afford.
07-10-2017, 02:39 PM #95
07-27-2017, 10:37 AM #96Member
- Oct 2007
- 88
- 10
- 31
- 48
07-27-2017, 05:46 PM #977000 RPM
- Dec 2005
- 2,124
- 642
- 288
- 1920
- 949
- 3 Post(s)
07-29-2017, 10:14 AM #98Member
- Oct 2007
- 88
- 10
- 31
- 48
07-29-2017, 02:03 PM #997000 RPM
- Dec 2005
- 2,124
- 642
- 288
- 1920
- 949
- 3 Post(s)
Nothing simple or easy Michael. A long time ago, we ran an OS boat with three RH units--it did not have power trim--it stretched the limits of Dual Ride Guide.
I made a LH unit by machining the teeth completely off the FWD gear, I think it worked pretty good (wasn't legal)--soon we got help from Mercury: LH rotation; full gear shift; bronze carrier; pretty good LH props---finding one of those units 50 years later??? Lots of luck--
07-30-2017, 11:04 AM #1007000 RPM
- Dec 2002
- South Florida
- 2,296
- 154
- 541
- 11 Post(s)
Can't you counter-rotate the whole motor? Some guys running Super Speedmasters used to doo that because the left-hand rotation lower had a much shorter life span than the rights. I guess this was because of having all the drive from both pinions going to a single two sided gear on the prop shaft. It would seem to me that keeping forward thrust on the forward gear in the case would be better. All this being said my lower unit experience was with 50s and 850s.
Mark75H thanked for this post
07-30-2017, 06:39 PM #1017000 RPM
- Dec 2002
- South Florida
- 2,296
- 154
- 541
- 11 Post(s)
Counter-rotating the motor won't work. The forward gear dogs face the wrong way. My bad.
GENE LANHAM liked this post
07-30-2017, 08:41 PM #102
WHAT? Steel at that price! But if like me, simple like to build stuff, then unload and "next project"? Screw the money..always can make more, but? NOT A TWIN MERC SWITZER! Miss my 74 SS17, XS, but?..oh well but..(been many boats since, all diff as fun)! Life?..USE IT UP!
08-22-2017, 12:18 PM #103Member
- Oct 2007
- 88
- 10
- 31
- 48
08-22-2017, 06:26 PM #1046000 RPM
- Sep 2003
- Clearwater, Florida
- 1,364
- 357
- 344
- 903
- 792
- 16 Post(s)
07-21-2018, 10:43 AM #105Member
- Oct 2007
- 88
- 10
- 31
- 48
