Results 1 to 6 of 6
Thread: repower and set up
09-28-2012, 01:48 AM #1
repower and set up
If I repowered to a 260 from a 200 would setup stay the same? just power head
Patriot Missile
09-28-2012, 09:40 AM #2
"Basic" setup should stay the same.... What I mean by this is you shouldn't have to make any major changes.
You will probably have to re-prop and adjust engine height slightly to dial everything in?
With the increased performance, you may end up noticing other problems that you were not aware of at the slower speeds...... such as handling problems.Thanks,
Tim Bostic
Hoss Marine Propellers
www.hossprops.com
918-479-5167 (shop)
Pugh Hydro w/260 Merc - 12" mid
1987 XB2002 Allison w/2.4 EFI Merc - 15" mid
1985 XR2002 Allison w/2.4 EFI Merc - 12" mid (Restoration Project)
"New" - 1987 XTB21 Allison (Refurbished at the Factory!!!!) w/'99-225 ProMax Merc
Top Speed Blog - http://www.screamandfly.com/blog.php...OSS-quot-Style
09-28-2012, 10:48 AM #3
I agree with Tim that the basic set-up will be fine. The extra ponies should allow for more performance which will probably be realized with a bit of experimentation. Kinda like starting all over but with improved results in the end. I would expect an optimized set-up with the 260 will be different than your current set-up. Good luck and have fun.
RockTeam Junk
10-01-2012, 06:50 PM #4
the 200 now will run the boat dry and fly around 80 i was told that to wind up a 260 you would need smaller pitch then the 28 i have now to spool up.
Patriot Missile
10-02-2012, 02:49 PM #5
I'd try the 28 you have now. The 260 is a beast compared to a 200. It's going to spin your 28 up higher anyway. If it's not enough, then you might consider dropping to a 26 or maybe a little smaller dia. prop? It is something to consider when making a major change in your boat.
Thanks,
Tim Bostic
www.hossprops.com
918-479-5167 (shop)
10-02-2012, 04:00 PM #6
as of now i am running the offshore 28 hoss. Its the fastest prop i have put on this venus .i do have alot of props now but no pitch biger than the 28p.
as of now it will spin over 7000 more like 7300 to 7400 with the 200 hp. i may need to go to a 32 or 34 .but the style prop should stay the same right?
Patriot Missile
