Results 1 to 10 of 10
    Mar 2010
    toronto
    Question OMC 90 deg v4 lower vs 60 deg v4 lower
    I have a Johnson GT100 with a standard v4 gear case. I also have a v4 Fast strike gearcase.
    other than the shape and slightly lower water pick ups, what is the difference?
    is the Fast strike v4 a particularly sought after case?
    I AM NOT INTERESTED IN SELLING EITHER CASE AT ALL!!
    but just wondering the ballpark values of each? Are they about the same?
    thanks
    southast ark
    Subscribed.....is the gt100 a crossflow?...i to would like to know if they will interchange
    Laser 1550 ...under construction with a serious weight loss
    Motor 2.4....undecided on hp yet
    May 2001
    Hickory NC
    The looper unit assembles different, it retains the pinion with a bolt from the top not a nut. It will fit a crossflow with a upper drive shaft change and shift rod.
    Mar 2010
    toronto
    Same gear ratio? And what ratio is that?
    May 2001
    Hickory NC
    2 to 1
    Mar 2010
    toronto
    Thanks for the info.
    So if I'm going to put a cone on it anyways does it matter which case to run, performance wise? either case will be just as good as the other?
    May 2001
    Hickory NC
    Installing a cone on a sub 80MPH boat will generally slow you down.
    Nov 2001
    Niagara Falls, NY
    This has had me thinking for years, after I installed the nosecone on my v4 lower I read this and thought I made a mistake.
    Last week I had time and a lower without nose cone and lower with.
    Here are my results on a viper, I was able to run the motor higher with the nose cone, got better water pressure and lower engine temp.
    The nose coned lower was .2mph faster on the same boat, same day. Prop is a Mazco RE3 26pitch.
    68.3 @ 6300rpm non-noseconed
    68.5 @ 6400rpm with nosecone
    Motor box stock, 1992 120 Looper
    Paul V.
    1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
    Feb 2003
    Chicago
    The nosecone minimizes the bow lift from trim on big pigs. Vipers don't need much bow lift because they are short and light.
    Aug 2004
    Venice, Florida
    Unless your boat likes stern lift. Mine wont crack 75 without a cone and runs low 80's with one.
    21' Paramount
    Mercury 300 Promax
