Results 1 to 4 of 4
    Jan 2005
    New York
    trim pump not going down
    I went down to boat today and motor wouldn't go down. I had put steering fluid in it originaly. Now I find out it needs motor oil. Well when I checked the can it had slug on the bottom. Is this normal. The motor runs and it seems to be air bound . I disconnected the up line and it drained out lowering the motor. Then I reversed the lines and ran it up down maybe trying to clean the lines out but it now moves in jerks .any solution or fluid I could use to clean out the system or just go with motor oil. Is this a lost cause ....
    Patriot Missile
    Sep 2002
    Panama City Fla.
    Try filling it with a very thin solvent or oil ( transmission fluid works also). Open the bypass valve and run the unit back and forth in both directions. Change or drain the "cleaner" fluid a couple of times before you install fresh oil. Tighten the bypass valve and try it. Sounds like trash in a check valve. This may or may not work but it's a shot at clearing it without a lot of trouble
    www.eagleoneperformance.com
    Jan 2005
    New York
    the bypass ,is that the black plastic screw inbetween outlet hoses?
    would you know the rebuild kit for sae j1171. or where the serial number would be?
    its on a ridgeback offshore single ram...
    ps thanks for the info and the poppet cover i bought from you it worked great..
    Thanks again
    Patriot Missile
    Jan 2005
    New York
    took it apart cleaned it and now shes flowing like new . thank god
    Patriot Missile
