Results 1 to 10 of 10
Thread: 30hp Yamaha mods?
08-21-2012, 06:50 PM #1Junior Member
- Aug 2012
- Becker, MN
- 7
30hp Yamaha mods?
New to the forum and tried the search but couldn't get the answers I was looking for.
I have a 1989 Yamaha 30hp that I want to get some more reliable power out of it. The motor is used for fishing and hunting but I want squeak out some hidden power if possible, nothing extreme just some basics. First thought is to mill the head but how much do I need to take off for running non-oxy premium? Also I see a aftermarket exhaust tuner is available. Are those worth it? I have some performance reeds already and the powerhead is solid. Any real experience with these motors is appreciated.
08-21-2012, 08:05 PM #2
Safe little wake up, cut .030 off the head and install 40 tohatsu carbs, yammi 40 reed cages and CCM reeds. Do not touch the exhaust.
11-20 -08 1980 14' Allison
2018 Carbon Fiber 15' Allison
homemade 15" 90 Yamaha
nice and quick 7900 rpm
Happiest driver on the board. Chris Carlson reeds are the way to go. CCM
http://www.youtube.com/watch?v=KQyBn...er_profilepage
08-22-2012, 11:09 AM #3Junior Member
- Aug 2012
- Becker, MN
- 7
Thanks for the info, already have the CCM reeds. What kind of compression would .030 give me and are the 40 Tohatsu carbs a bolt on?
08-22-2012, 07:47 PM #4Junior Member
- Jun 2012
- louisiana
- 24
The carbs with the cages Jason mentioned are a bolt on, he would know the psi gain from milling.
08-22-2012, 07:52 PM #5
If you cut .040 the pistons will ever so lightly touch, that will give you 150psi. then you remove the head again and lightly sand the pistons. the word UP will transfer from pistons to head. .030 should be 135 - 145. The tohasu carbs are a little work, not bad though, got to restack them, mid to bottom bottom to mid. You need to cut open the carb plate, blend the holes. Also a little work for the vacume to the fuel pump. But a afternoon job at most. Don't forget the 40hp yammi reed blocks.
08-30-2012, 11:22 AM #6Junior Member
- Aug 2012
- Becker, MN
- 7
Where do I find the Tohatsu carbs? What years work? I did a google search but couldn't find any info.
03-28-2017, 01:37 PM #7Junior Member
- Jun 2010
- Louisiana
Yammi 30 mods
I had a stock 25 3-cylinder on an Xpress 1546VJ jack plate stock motor just me ran 28MPH with a Power Tech SRA3 11 pitch turnin 5600RPM. Added 40/50 stock reed cages, 40 carbs opened intake to match carb venturi, shortened 30 tuner cut off just at water intake. Boat ran 43MPH at 6400 RPM Turbo hot Shot 13 pitch. This was just me 185lbs and 6 gallons of fuel. Hope this helps..
03-28-2017, 02:48 PM #8
I've got a clean set of pro v 50 Yamaha carbs if you can use them. Jason knows ! He was flying after fixing the flooding problem. Good show ! Mike
Cheaters never Win !!!
05-15-2018, 01:31 PM #9New Member
- May 2018
- Iowa
What is the reasoning for not touching the exhaust? Sorry just curious and I'm trying to figure out best set-up on my yami 30 mshr.
05-15-2018, 03:57 PM #10
