Results 1 to 11 of 11
    Aug 2012
    Kelowna, British Columbia
    Help - intermittent noise
    Odd noise tonite while out on the lake. 1999 Mariner Optimax 150. Out running around at about 4000 RPM and starting getting a knocking noise from outboard. Back off and noise goes away, get back into e throttle and noise comes back. Back off to idle, let boat slow down, punch it and no noise, but then sometimes a few seconds and sometimes a few minutes before noise coming back. Always seems to be when on plane cruising around. Any thoughts? Doesn't seem to matter what RPM I am cruising at the noise eventually shows up. Could it be a clutch issue? Running a high five prop and no previous issues but have not had the boat very long.
    Thanks for any help.
    Jul 2008
    Binghamton, NY/ Raquette Lake, NY
    I'd start by taking a real good look at the air compressor. Pull the belt off and spin it by hand. See if you have any play anywhere.
    '72 Glastron GT-150 Johnson Stinger 65
    '83 Hydrostream Varmint 2.4 225 Mercury
    '05 Hydrostream Voyager 250xs optimax
    Aug 2012
    Estacada Or
    Quote Originally Posted by gregpro50 View Post
    DITTO.. how many hours are on the motor.. .they have a tendancy to fail after 300-500 HRS...
    Feb 2012
    Central Pa
    Try a different prop. Could be a harmonic imbalance between the prop/driveshaft/crank/flywheel. Have seen some give the symptoms you are describing because of certain SS props. The older inline 4 cyl's were notorius for it. Some of them you couldn't even run a SS prop. I have seen some Opti's do it too.
    Worth a look before you dig deeper. Changing a prop is easy just to check it.
    Also check the belt tensioner. They had a bad habit of breaking the boss of the block !
    b0atguy
    1986 Hydrostream Vegas XT
    Mercury Bridgeport EFI
    Brucato ACU
    CCM Drag Reeds
    Aug 2012
    I thought I would try a new prop tomorrow, but I will definitely check the compressor and the tensioner before I go out.
    Would any of these issues cause an intermittent noise?
    Aug 2012
    Forgot to add local dealer scanned it when I bought and I was told 22hrs. Boat has been sitting for last 6 - 7 years.
    Aug 2012
    seaford New York
    does the motor jerk when the noise is present or only make noise?
    Aug 2012
    It does not jerk, only makes noise.
    Pennsylvania
    Check to ensure that your flywheel is tight.
    Aug 2012
    Looks like I wont be able to get out on the water today to try a different prop. I did check the air compressor, no bearing issues, no slop in the pulley. Check the belt tensioner- no problems there. Checked the flywheel, it's tight.
    One thing I did notice was that the intake for the air compressor was missing the grommet for the flywheel cover. Do the air compressors ever go into a unload state where air could exhaust out the intake casing the cover to thump up and down? Just a thought. Don't want to do too much arm chair diagnosing with out going and trying a different prop as b0atguy suggested.
    Jan 2008
    eatonton ga
    had one doing same thing not a opti but wound up being the gearcase lost one tooth off the pinion very hard to diagnose just a random clunk or knock sound
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    97 xr 2001
    89 stv pro comp
    CURRENT RIDES
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    89 Stv pro comp
Mazco
