Results 1 to 4 of 4
    Jul 2008
    Binghamton, NY/ Raquette Lake, NY
    '05 Opitmax 250xs general questions
    I just bought a boat with an '05 Optimax 250xs. It is not the Pro-XS it is the one built by Mercury Racing. I know nothing about these motors other than it is supposed to run 91 octane. The next newest motor I have ever owned was an '86.
    Do the Mercury racing motors take a special oil other than the optimax oil?
    Does the lower unit take a special gear lube?
    What is the difference between a regular 250 optimax, a 250 pro xs, and a 250xs?
    Are they generally supposed to be reliable motors? The one I have is supposed to have under 100 hours and was owned by an older gentleman who seemed to take really good care of everything. He said 99% of the time the boat was run under 40mph.
    '72 Glastron GT-150 Johnson Stinger 65
    '83 Hydrostream Varmint 2.4 225 Mercury
    '05 Hydrostream Voyager 250xs optimax
    Nov 2002
    Tucson, AZ
    I have 2 of same year, same model. Only major issue was sportmaster gearcase, pushed shiftshaft seal out and ruined internals. Owners manual says Merc Premium Plus 2 stroke oil. If it is sportmaster it takes Hi Prformance gear oil(green oil). As for the difference I know XS has solid motor mounts, not sure about other differences but think it turns a little higher RPM than other two. They come in a single ram trim(HD) and 3 ram trim(standard duty). Mine have about 170 hrs.
    Jul 2008
    I'm confused by the oil recommendations. The manual says premium plus tc-w3 but the dealer says to use Optimax dfi oil which is not tc-w3 compatible. I know the previous owner used dfi oil.
    Mercury came out with a bulletin in 2010 that you should only use DFI oil in the opti contrary to what the manual said.
