Results 1 to 5 of 5
    Apr 2008
    Malta
    trim sensor on heavy duty swivel bracket
    Do heavy duty swivel brackets take 841198A1 trim sensors? I have bought this sensor and it seems it doesn't fit anywhere on this bracket.
    http://www.mercruiserparts.com/Show_...8Heavy+Duty%29
    This is a 2002 300x
    Your help is much appreciated!
    Apr 2008
    Malta
    any help anyone?!
    Moline,Ill
    I thought they did away with those a long time ago but, if you take off the retainer plates that hold the pin in the trim cyl., you can tell if it's keyed(slotted)to accept the sender
    Apr 2008
    Malta
    hi and thanks for your reply.
    are you referring to item 18, if so nope it doesnt fit their either.. Click image for larger version.
    He's referring to the earlier heavy duty clamp, with the switch mounted in the saddle. The configuration on the newer engine you have appears to be different.
