Results 1 to 15 of 29
06-27-2012, 02:05 PM #1Member
- Jul 2008
- New York
- 96
- 10
- 20
unexplained water in the bilge =(
about two weeks ago me and a couple buddies were out and got caught in a storm, knocked us around pretty bad. (4 foot breakers in a 17ft action ) yeah lol.
anyway, iv taken the boat out a couple times since then and iv noticed a lot of extra water in my boat that seems to be unexplained. i usually have some in there just from the waves/water rushing over the transom when coming off plane or doing other fun stuff but the amount and frequency that ive been pumping out water just doesnt seem right. is it possible for the seal to be broken between the top and bottom halfs of my hull? I cant seem to find any other place that water might be coming in.
06-27-2012, 02:08 PM #2Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Take a water hose and spray hard around the rubrail. Look for leaks in side.....
06-27-2012, 02:11 PM #3
If that doesn't show any water, try what I did......
With the boat on the trailer, take a garden hose, and put an inch or so of water INSIDE your boat....then lay under the boat and see if any water drips out of an unseen crack.
I did that on my Quartershot when it was getting water in, and I couldn't find any cracks with just my eyes.....I found the drip, and then I knew where to start my work...JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
06-27-2012, 02:23 PM #45000 RPM
- May 2011
- Ft. Lauderdale
- 625
Start simple, make sure your drain plug just isn't worn out.
06-27-2012, 02:42 PM #5
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
06-27-2012, 03:14 PM #6
After a particularly hard trip like that you may find water tracking in via through hull fittings and bolts which have had the seal broken by the twisting of the hull (bow rail for instance).
Wellcraft Nova 230 XL, 300hp Johnson.
Seahawk 45 Sport Fisher, twin 306hp Volvo.
Steadcraft 28, Yanmar 300hp. Sold.
Markline 800, Volvo 300hp. Sold.
Haines Hunter V19, Volvo 170. Sold.
16ft 6in Figlass Sidewinder, 140 Suzuki. Sold.
06-27-2012, 03:50 PM #7
This happened with my boat.
Water leaking around a bad poppet gasket on the block..tracked via my cables, back into the bildge area.
I could not believe the amount of water that came in via tracking. I spent a few weeks checkin this checkin that..before I found the problem.
Good luck.
06-27-2012, 05:48 PM #8
Check the bilge pump discharge. Water may be getting back in through the discharge hole if it is near the water level especially since you said you were in a storm the wave could wash in the discharge. I had that problem with my last boat and had to put a big loop in the discharge hose to work as a trap.
Ralph Musser
27' Fountain Fever W/ 525SC
22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
24' Triton 240 Gold W/ Mercury 60
14' Royalcraft W/ Evinrude 75 father/daughter project
06-27-2012, 06:12 PM #960 glasspar g3 115 merc (sold)
17 Action Marine 2.5 Mariner (sold)
18 Seebold Eagle 2.5 merc (sold)
23 Action Marine 3.0 merc (sold)
18 Action Marine 2.5 merc (sold)
32 scorpion twin 225
Run What Ya Brung And Hope Ya Have Enough
06-27-2012, 06:12 PM #10
take a look
06-28-2012, 08:24 AM #11Member
- Jul 2008
- New York
- 96
- 10
- 20
thats a pretty bold statement but I will check. I took the boat out yesterday for a little test. when im just idling through the canal, the bilge seems to stay dry. but then when i went out into some rougher waters and came back there was GALLONS of water in the hull, i mean an unsettling amount and it was probably only a 30 minute run. granted though, the boat was out of the water a few times . this never used to happen until quite recently though, even when having a little fun with the waves. ill check all of the aforementioned areas that you guys suggested
06-28-2012, 09:08 AM #12
An unseen crack in the bottom, and beating it on waves could cause a bigger crack and delamination...
JOHN MASON
06-28-2012, 06:41 PM #1360 glasspar g3 115 merc (sold)
06-28-2012, 08:09 PM #14
transom bolts to ??
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
06-28-2012, 11:04 PM #15
Let me say this louder than Waterwings. You got beat up in bad water pretty bad, and now there is a lot of water in your boat. Seems to come in while on plane, not through the rubrail/hull-to-deck joint. It is possible that you have a crack in the bottom. I would sure do the "fill it with water and look for leaks coming out" test before I would run that boat fast. That crack, if it exists, could open catastrophically and kill you.
Per Rock:
"Once I bought my first Hydrostream boating changed forever for me."
Per my hero Instigator:
"I try not to let common sense interfere w/my boat buying decisions."
Pat Gent
cell 954-249-3246
'78 Hydrostream Vandal (being rebuilt)
'86 21' Eliminator Daytona, 300 OMC V-8 (Li'l Toy III)
