Results 1 to 11 of 11
    Jul 2004
    Orlando,FL
    Best product to paint floor bilge
    What is the best stuff to refinish bilge in like white also thre floor/sides area. Interlux bilgecoat?
    90 Vegas 89 200 78mph
    North Branch & Pine City, Mn.
    Quote Originally Posted by 200VEGAS View Post
    Yes, good product. Like everything, the key to success is prep. Lacquer thinner does a good job of prepping bare wood or cleaning existing glass. You may want to scuff it too.
    The Reverend, (Cedar Machine Service on Facebook)
    1989 HST 2.5 260 Merc Offshore
    1991 Vaserette YT 200 Mercury
    1988 Venus XT 200 Yamaha
    1983 Viper II Merc 90
    1977 Viper
    Mini GT tunnel, 25 Merc
    "African Queen" pontoon 25 Merc
    Aluma fishin tub, 20 motors to choose from!
    GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
    JUPITER, FLORIDA
    Here's what a freshly BilgeKoted bilge looks like:
    J-Town Hot Boat Team
    Barracuda 188CCR/Suzuki 140
    Past Boats:
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT Bowrider/Merc 175
    Talon T-21/Mercury Racing 2.5 Carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/Mercury 454 Magnum
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat/Mercury SportJet
    SeaRay 17' Seville/Merc I/O
    Apr 2011
    grove ok
    I have been using a bed liner material called Raptor Its a 2 part urthane comes in a 1 gal kit with a spray gun This stuff is tough as nails good adhesion has a non skid texture It covers 24 grit scratchs comes in black and a tintable color. You can adjust texture by adjusting air pressure and thinning. Drys to satin finish that is hard not spongy like most bed liner materials
    Miami,Fl
    How much prep before you apply is there any forgiveness?
    Jun 2001
    Kentucky
    also look up durabak
    Apr 2011
    grove ok
    The first time I used it was on a Jet Ski where the rubber foot pads were torn up I spent a lot of time on the prep sanding and primering surface and 320 sanding primer. After shooting it I discovered I had way over done it. The next time was on a boat I had replaced transom and stringers I completed glass work flow coated and finished with 80 and shot. Next time was a freshen up bilge before installing motor I washed out oil and crap with Simple Green grab small hand grinder with 36 grit disc gave it a lick and a promise cleaned with laq thinner and shot It came out as good as the Jet Ski I spent 4 hrs on Prep.The bilge was just woven roving geled over from factory the stuff covered the roving pattern and looked like I spent a day or so on prep
    Bristol, WI
    Has anyone tried the rustolium bath tub epoxy? Ive done 5 bath tubs in some of my rental houses, it goes on very easy and is very durable to wet conditions (obvously). Any thoughts? Thinkin about using this on my twister this spring.....
    Jr.
    Larry Gempp Jr.
    Apr 2006
    Viera (Melbourne), FL.
    Yes I used it in a bilge and it worked well. I never tested it by leaving standing water in the bilge for any length of time so I don't know if that will cause it to lift.
    Jul 2008
    Binghamton, NY/ Raquette Lake, NY
    I've used black swimming pool paint with good results. I imagine the white would work just as well.
    '72 Glastron GT-150 Johnson Stinger 65
    '83 Hydrostream Varmint 2.4 225 Mercury
    '05 Hydrostream Voyager 250xs optimax
    Cape Coral fl
    Interlux Perfection The Best
