Results 1 to 11 of 11
06-20-2012, 05:28 PM #1
Best product to paint floor bilge
What is the best stuff to refinish bilge in like white also thre floor/sides area. Interlux bilgecoat?
90 Vegas 89 200 78mph
10-07-2012, 12:56 AM #2The Reverend, (Cedar Machine Service on Facebook)
1989 HST 2.5 260 Merc Offshore
1991 Vaserette YT 200 Mercury
1988 Venus XT 200 Yamaha
1983 Viper II Merc 90
1977 Viper
Mini GT tunnel, 25 Merc
"African Queen" pontoon 25 Merc
Aluma fishin tub, 20 motors to choose from!
GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
10-07-2012, 12:56 PM #3J-Town Hot Boat Team
Barracuda 188CCR/Suzuki 140
Past Boats:
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT Bowrider/Merc 175
Talon T-21/Mercury Racing 2.5 Carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/Mercury 454 Magnum
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat/Mercury SportJet
SeaRay 17' Seville/Merc I/O
10-08-2012, 08:01 AM #4Member
- Apr 2011
- grove ok
- 83
I have been using a bed liner material called Raptor Its a 2 part urthane comes in a 1 gal kit with a spray gun This stuff is tough as nails good adhesion has a non skid texture It covers 24 grit scratchs comes in black and a tintable color. You can adjust texture by adjusting air pressure and thinning. Drys to satin finish that is hard not spongy like most bed liner materials
10-08-2012, 08:49 AM #5Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
How much prep before you apply is there any forgiveness?
10-08-2012, 10:38 AM #6
also look up durabak
10-09-2012, 07:58 AM #7Member
- Apr 2011
- grove ok
- 83
The first time I used it was on a Jet Ski where the rubber foot pads were torn up I spent a lot of time on the prep sanding and primering surface and 320 sanding primer. After shooting it I discovered I had way over done it. The next time was on a boat I had replaced transom and stringers I completed glass work flow coated and finished with 80 and shot. Next time was a freshen up bilge before installing motor I washed out oil and crap with Simple Green grab small hand grinder with 36 grit disc gave it a lick and a promise cleaned with laq thinner and shot It came out as good as the Jet Ski I spent 4 hrs on Prep.The bilge was just woven roving geled over from factory the stuff covered the roving pattern and looked like I spent a day or so on prep
03-05-2013, 12:52 PM #8
Has anyone tried the rustolium bath tub epoxy? Ive done 5 bath tubs in some of my rental houses, it goes on very easy and is very durable to wet conditions (obvously). Any thoughts? Thinkin about using this on my twister this spring.....
Jr.Larry Gempp Jr.
03-05-2013, 01:57 PM #9
Yes I used it in a bilge and it worked well. I never tested it by leaving standing water in the bilge for any length of time so I don't know if that will cause it to lift.
03-05-2013, 03:10 PM #10
I've used black swimming pool paint with good results. I imagine the white would work just as well.
'72 Glastron GT-150 Johnson Stinger 65
'83 Hydrostream Varmint 2.4 225 Mercury
'05 Hydrostream Voyager 250xs optimax
05-15-2013, 09:36 PM #11
Interlux Perfection The Best
