Results 1 to 3 of 3
    How to remove bleed check valves 200 efi 1998
    A nipple has broken off the bleed check valve on the bottom of the block... what is the best way to remove this?
    thx in advance
    Sep 2002
    Panama City Fla.
    Sometimes you can take some vice grips and remove them if you don't clamp down too tight as they are just pressed in in most cases ( the older engines had a screw in model which is far better) Just be careful not to crimp it any at all or put heat on it as it has a small plastic ball inside. Sometimes taking a punch and tapping it side to side helps. If all else fails just twist it out with some pliers and buy a new one to install. If the inside breaks off an EZ out will usually remove the piece. Just another example of where saving 10 cents on a press in versus a screw in model will make a better bottom line for the manufacturer. The old screw ins were easy to install or remove and lasted almost forever. I believe the check ball in them was stainless. I've bought them before and drilled and tapped the block so I could use them. Takes a little time but the problem is solved forever. I think the list price for them is about 6-7 dollars each. We sometime have some in stock when we can get them.
    www.eagleoneperformance.com
    Bleed check valve extraction
    thx Eagle, I'll give it a try
