Results 1 to 7 of 7
05-28-2012, 03:13 PM #1Junior Member
- Oct 2011
- Potomac creek, virginia
- 19
1973 evinrude 85 is running rough at idle speed in gear.
Hey there, my evinrude 85 is acting up again. The motor starts fine and idles fine, but when it's put in gear there's a lot of vibration at low rpm. I checked the prop, it's ok no dents no dings. I also had to change bothe control cables. I'm wandering if the cables not being in adjustment could have something to do wt it?? Thanks
05-28-2012, 03:16 PM #2
Does it run OK other wise? Maybe just idled to low.
05-28-2012, 07:56 PM #3Junior Member
- Oct 2011
- 19
05-28-2012, 10:55 PM #45000 RPM
- Jul 2007
- Chatsworth, CA
- 116
I had a 1973 135HP and I know you have to have the correct plugs in it for it to run good. Also is the electric choke free? Or is it bound up? How is comperssion?
Second Place is the First Loser!!!
05-29-2012, 07:11 AM #5Junior Member
- Oct 2011
- 19
05-29-2012, 08:16 PM #6
Replace the plugs with new ,and run full synthetic oil thanks.
free spirit / ONTARIO, CANADA.
06-06-2012, 12:40 AM #75000 RPM
- Feb 2012
- Canada
- 346
How long ago have you checked the comp---It takes 1 flat-out run with crappy fuel to destroy a crossflow (ask me how I know)
if compression is good I would check the throttle linkages next (to see if the carbs open at the same rate.)
