Results 1 to 15 of 20
05-06-2012, 08:05 PM #1Member
- Jun 2002
- Lake Norman NC
- 52
Is this motor REALLY a 1978 200hp?
Long-time lurker here- and now that I'm an outboard owner at last- I will have some questions for you Merc outboard guys.
I recently bought a boat with what the owner described as a 175 with 200hp markings- he supposedly knew of this before he bought it himself back in the early Eighties. It's described as a 1978 200 with s/n 5364431 on the plate. The external decal of course calls it a Black Max 200.
Since I've learned from this forum that there were no 200hp 2.0's ever built, what physical differences are there on the 2.4 that would separate it from a 2.0 that a newbie could determine? What photos could I take and post to make it easier for the experts to see for themselves?
Thanks in advance- I'm hoping to try and fire this thing up sometime in the next week or so- more questions then.
DaveA1972 Raysoncraft 18LP v-drive Chev 454
1975 Raysoncraft 17' outboard 200Merc 2.4
1989 Celebrity 199 I/O 350 Chev ZZ3/Alpha
2001 Baja Outlaw 25- 496HO/Bravo
05-06-2012, 09:31 PM #2
2 liters and 2.4's will have the bore size stamped on the face of the head near the top.....3 1/8"= 2liter..... 3 3/8"=2.4. Someone still could have swapped the heads from one motor to another.
05-06-2012, 09:46 PM #3Scream And Fly VIP
- Sep 2002
- Alabama
- 705
That is not true on V6 Mercs made in the 70's. And back then the heads between the 2.0 and 2.4 did not interchange without doing some changing on the bolt pattern. The bosses for the headbolts on the early engines were on the side of the casting for the cylinder rather than the block as they were done later. Early 2.0s would have a distinctive bolt pattern. I dont remembrer the diameter but if nobody else posts it up tonight I can measure one tomorrow. I think there are other obvious external differences but Im drawing a blank. It is very easy to tell with the exhaust divider plate removed because the 76,7,8 2 liters had that funky shape at the bottom of the powerhead where the 2.4s were rectangular.
bama hama
05-07-2012, 12:04 AM #4Member
- Jun 2002
- Lake Norman NC
- 52
I've checked the heads with the cowl open as much as possible and I see nothing on the heads as described. Here's some photos of what I did see.
05-07-2012, 12:08 AM #5Member
- Jun 2002
- Lake Norman NC
- 52
The first photo is of the top of the engine as you can tell. The second is of the pad on the base of the left head near the top. The bottom one is the numbers on the midsection. There's a number stamped between the heads at the base of the engine in the back that I cant read unless I remove the cowl. I took a mirror and looked at the tops of the heads- there's a number there along with the Mercury Marine logo, but it's not anything like 3-1/8 etc.
05-07-2012, 12:57 AM #6Scream And Fly VIP
- Sep 2002
- Alabama
- 705
It was nice of somebody to put an aluminum flywheel on it for you.
bama hama
05-07-2012, 07:50 AM #7
The early 2.0 heads will fit on the early 2.4's, just sayin'.
05-07-2012, 11:16 AM #8
That appears to be a 2.4 block. The dead giveaway is the smooth "ramps" on the top of the block leading to the heads. The 2.0L blocks had a "boss" cutting into the ramp on the top of the block to accept the longer thermostat bolts . The 2.4's did not have the "boss".
I would say you have a 2.4 block, possibily an 81. You can easily tell the HP by looking at the cylinder block on the port side, where the halfs meet approx around where the timing advance stop is. If its a 150, there should be a 5 stamp. If its a 175, it should be a 7 stamp. If its a 200, you should have a 2 stamp. I have several powerheads sitting here, 2.0L and 2.4L. If you need any pictures of anything let me know. I Just checked them, to confirm the numbering.
b0atguyLast edited by b0atguy; 05-07-2012 at 01:31 PM.
1986 Hydrostream Vegas XT
Mercury Bridgeport EFI
Brucato ACU
CCM Drag Reeds
05-07-2012, 11:43 AM #9
If you lift straight up on those cowling halves, they will easily lift off, one at a time. Each side has two pins that drop into sockets on the back end. It's really easy.
05-07-2012, 11:58 AM #10
I see "81" stamped at he block 1/2's......
JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
05-07-2012, 12:19 PM #11
It appears as if someone has cut the heads down as much as possible too.
Roblunday@gmail.com liked this post
05-07-2012, 10:17 PM #12Member
- Jun 2002
- Lake Norman NC
- 52
This is exciting- I think I got a 2.4 200 after all- here's more photos- what do you guys thinK?
I hope this is the number 2 you're talking about---
You guys think these heads have been machined?
Port side of engine
Guess what else it needs- any suggestions on replacements?
05-07-2012, 10:24 PM #13Member
- Jun 2002
- Lake Norman NC
- 52
This is great- thanks for such good information!
MercNuts, didn't notice the aluminum flywheel- BONUS. Thanks!
Pyro- that was so simple & I didn't even think of it. Thanks for the reminder...
b0atguy- hope the photos confirm what you've been saying. 2.4?
capt insane-o: you still think the heads have been cut?1972 Raysoncraft 18LP v-drive Chev 454
05-07-2012, 10:36 PM #14Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
its a first generation block with head bolts attached to the sleeves( it looks like)
05-07-2012, 10:37 PM #15Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
prop shafts are plentiful
