Results 1 to 13 of 13
    longisland ny lindenhurst
    Question sleekcraft modvp blowout help!
    Whats up guys,need some help on setting up one of my boats.Its a 21ft sleekcraft modvp hull.It has the 24inch built in set back in it.I have a bridgeport on it slightly worked with a 14.5 30clever,1:87gears.I redid the whole boat over winter(stringers,dash,transome ect.)I rigged the boat with the battery about 4inchs behind the driver seat and the gas tank right behind the battery.i had the motor on the bottom last hole which brings the shaft level with the pad.I was getting blowout at 90-91mph revs were about 67-6800 and still climbing if blowout didnt happen.I thought the motor was to high so i dropped it a hole now its about 1/2' below pad.Went out for another spin going into the wind it ran 94 at 7000 no blowout,but as soon as i turn around and go with the wind i get blowout at 92mph at 6800rpm.I believe the motor has to come up to get my revs up but i cant bc of my blowout situation so im thinking on moving my tank and battery as far back to the transome as possible.Im just alittle on the freaked out side of not having enough weight up front and not blowing out but blowing over.Does any1 know if these hulls run good with weight in the rear and the bow hanging high?Im going to spend all season long dialing this boat in but if some1 can give me alittle help on setup so i dont waste my whole summer i could really use it.This is my first tunnel boat i have about 6years of seat time in a 16ft superboat so switching over from vhull to tunnel is a different ball game.Thanks guys
    edd
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt
    20ft Allison grandsport
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    Jun 2008
    kingman az
    not sure about the sleek craft but i know my stoker runs better the further back you put the internal weight...i would say give it a shot and experiment moving the weight around and see if it makes a difference. take care with the trim button...it sounds like you already know that....stay safe and keep it right side up!
    shaun
    upstate N.Y.
    IMHO,too much setback!
    why ask me ?
    May 2011
    Islip NY
    my sleek had 16" setback and i ran the prop shaft 1.5 to 2 " higher then pad i was running mid to high 80mph with a 225 mercury 3.0 never blow out hope that helps .
    Jun 2008
    kingman az
    Quote Originally Posted by stokernick View Post
    the set back is built in....sleekcraft made a few of these back in the mod-vp hay day that were super light and are now pretty rare...it seems like the sleekcraft sst needs a lot of set back to get them to fly
    i almost bought this one when i was 16...it sold just before i came up with the $$$
    Sep 2002
    Which gearcase are you running?
    1:87 cle with a nosecone on it.i also got 14inch tunnel tabs for it,but those will prob make the blowout even worse.
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    upstate N.Y.
    think about a teeter totter,I just think it's out of balance!!maybe a heavier 3 liter would even it up!
    why ask me ?
    Sleekcraft Mod VP w/ 2008 Evinrude E-tec 250HO
Name:	Sleek and etec.jpg
    20’ Sleekcraft Mod VP
    2008 Evinrude E-tec 250HO w/ Bob's Machine Shop Big Foot Nose Cone
    28” Raker
    PL-65 HS 5-1/2" Set-Back High
    Gaffrig gages with GPS
    82 mph @ 5800 rpm
    upstate N.Y.
    Quote Originally Posted by pritchhd View Post
    28” Raker
    82 mph @ 5800 rpm
    see the difference?? Get rid of that setback!! 5 1/2 works great!!
    why ask me ?
  12. #12
    Jun 2008
    kingman az
    Quote Originally Posted by 16ft superboat View Post
    thats the one i almost bought years ago....that boat has run over 100 with a 2.4 on it....ill see if i can track the original owner down and put you in touch with him...i know he was running a cleaver on it when he raced it...careful with this one its super light
  13. #13
    yeah that would be sweet.i moved the gas tank back by the transome just went out for a ride brought it up to 91mph at 6700 and still pulling hard no blowout so far but i couldnt hold it WOT to long started to get rough out there had to come back in
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
