Results 1 to 15 of 19
Thread: Valero Setup
04-20-2012, 11:18 AM #1Member
- Jan 2012
- Michigan
- 74
Valero Setup
I am getting My Valero ready for paint and rigging I am looking for some intel on some stuff whats the factory weight on one I got all the core replaced with the green board stuff and new floor transom and splashwell delete the boat seems super light I am wondering what I can expect with a 200 carb Merc with a CLE and how much setback will I need I will be running a hydro jacker and what prop size would be a good start should be a kick a@@ boat for a vbottom stream I am curious what type of sppeds I should expect thanks S&F
04-21-2012, 04:31 AM #2
Is is a V hull or a YT? Which 200? 2.0, 2.4, 2.5?
Ill guess a little:
A v-hull will run high 70's low 80's set up right with 6-8" of setback. Start out with a 26" Merc Chopper. It's a great baseline prop that gives good lift.
Im guessing it's a 2.5L 200... If its a 2.4 or 2.0 liter, it may have slightly less punch and top end.
I have seen real primo-set up Valero/200 combos hit 90 but it's gotta be perfect and it wouldn't be a stock motor.The Reverend, (Cedar Machine Service on Facebook)
1989 HST 2.5 260 Merc Offshore
1991 Vaserette YT 200 Mercury
1988 Venus XT 200 Yamaha
1983 Viper II Merc 90
1977 Viper
Mini GT tunnel, 25 Merc
"African Queen" pontoon 25 Merc
Aluma fishin tub, 20 motors to choose from!
GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
04-21-2012, 07:03 PM #3Member
- Jan 2012
- Michigan
- 74
its a 2.4 liter 20in 200 merc I may consider some light mods after I get things set up
04-22-2012, 12:42 AM #4
V hull or YT?
1977 Viper
04-23-2012, 07:45 AM #5Member
- Jan 2012
- Michigan
- 74
Oh sorry I took my moron pill lol its a v bottom Valero
04-23-2012, 08:24 PM #6
She will fly nice and loose with that 200. 80+ is a reality. That is one mean V Hull.
1977 Viper
04-24-2012, 10:54 AM #7Member
- Jan 2012
- Michigan
- 74
Wow should be fun can't wait hopefully gonna have her ready for primer by the end of the week and then I need to get her flipped for paint and start rigging
04-24-2012, 12:25 PM #8
Hi
I own a Valero V buttom with a 150 xr6 which means it's a 2.5.
I run my boat with a 6 inches setback, with a manual jack, and I have a 28 chopper or a 24 chopper, both does pretty the same except rpm and wholeshot, into the low 70
my gaz tank is at the front,
my batteries are at the back passenger sideLast edited by Yubz; 04-24-2012 at 12:28 PM.
The only difference between kid and adult, it's their toy size !
04-24-2012, 01:17 PM #9The Reverend, (Cedar Machine Service on Facebook)
1977 Viper
04-24-2012, 01:33 PM #10
I was wondering about moving my tank at the back. My concern is that te tank dosen't fitt at the back, it is to big. I have around 20 gallons of gas into my tank. If I ride one total day non-stop I fill it during the morning and when I come back. I know and I want to, but I'm getting tired of throwing my money into my boat. I was thinking with the gaz tank at the front is better for the waterski. Am i crazy or not so bad, don't worry, I want to know which is good or not !
04-24-2012, 07:27 PM #11Member
- Jan 2012
- Michigan
- 74
If your a huge ski fanatic are u interested in a 7ft tall removable ski pylon its called a skyjac ski pylon I have all the mounts
04-25-2012, 08:12 AM #12Member
- Jan 2012
- Michigan
- 74
I was thinking about putting my battery in the bow and keeping my fuel cell in the rear after I get the hull up and running I am gonna move up my backseat and build a small sunpad and then redo the upholstery next season its in good shape but its tome for a color change
04-26-2012, 08:54 AM #13
tell me more about this ski pole !
04-26-2012, 09:02 AM #14
No fuel tanks in the bow--ever!
There is plenty of room for a 20 gallon tank, battery and even oil tank in the stern.
If you're not a heavy driver and don't carry heavy passengers, you could mount a lighter battery (Odyssey PC925 works well) up front just in front of the bulkhead, on the port side.
John
04-26-2012, 10:17 AM #15
If you calculate the work for doing it, cause my tank dosen't fitt, I need to buy a new tank, take off the old one, change my fuel line everythin, does it worth it ?
