Results 1 to 15 of 69
Thread: 140 cross -flo.
04-11-2012, 11:55 AM #1
140 cross -flo.
Anyone know how to run a 140 cross-flo. 7,400-7,500 RPM. with out useing the [strangler[ v4 8 barrel carb. system thanks?-----------------------------------The set up is a viper.
free spirit / ONTARIO, CANADA.
04-12-2012, 11:54 PM #25000 RPM
- Feb 2012
- Canada
- 346
Maybe a diff. "tuner" -L-O-L-
(remember me)
04-13-2012, 11:54 AM #3Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
We used to run the stranglers with the standard 4 barrel intake in order to run a second class it would loose from the 8 barrel but could still get them well into the 7k range.
04-13-2012, 09:33 PM #4
Does this mean you ran strangler moded power head, as opposed to production 140 v4 thanks ?
04-14-2012, 10:00 AM #5Registered User
- Apr 2010
- Vacherie, LA
- 58
I've been running a 115/140 conversion on my viper for 2 years now and have turned it up to 7600 rpm for a while. The engine has factory porting & pistons(non-scalloped) and that was as far as I wanted to push it on a lake motor. Now besides sounding great at that rpm(nothing sounds like a v4 crossflow IMHO), I have since propped it to turn ~6700 hopeing to make it live a little longer.
There is nothing special about the engine either; 140 heads, '77 tuner, cut can, 1 5/16" carbs, boyesen, etc. The cylinder porting has not been raised but, everything has been radiused. Including the bubble-back & block where the exhaust re-enters. I have upgraded the wrist pin bearings though. A simple build on a really simple engine that runs great and makes awesome fuel mileage.
I have been thinking about building another powerhead with the 2.6 v6 mods( a la Racer) but this thing is running so well I'm undecided... Good luck with your build and if a v4 crossflow makes you smile at 6000 rpm, you should try 7600, lol!Last edited by Superstocker; 04-14-2012 at 12:00 PM. Reason: Loves to outrun v6's!!! Lol!!!
04-14-2012, 11:32 AM #6Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Upgraded rod bearings?
04-14-2012, 11:59 AM #7Registered User
- Apr 2010
- Vacherie, LA
- 58
Sorry, my bad. Not rod bearings. I meant wrist pin bearings. I went with an "uncaged" wrist pin bearing.
04-14-2012, 05:39 PM #8Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
What do you use as a grease and/or method to assemble the needles?
04-14-2012, 05:57 PM #9
04-14-2012, 08:29 PM #10
04-14-2012, 10:04 PM #11
04-15-2012, 12:17 PM #12
I use vaseline petroleum jelly.
04-15-2012, 12:44 PM #13
04-15-2012, 07:42 PM #14Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
hard to believe 7600 is a good rpm to run with stock ports??
04-15-2012, 07:52 PM #15
I'm with powerabout, there can't be too much power left at that engine speed. Mine seems to run out of steam at about 6000. I could prop it smaller but I'm certain the boat would slow down. I guess if you are drag racing and need the acceleration more than top end it is justifiable.
