Results 1 to 15 of 18
    Sep 2009
    Miami
    Paramount fuel tank issues
    I have a 2003 Paramount with a 2003 Yamaha VMAX 200 and Yamaha electronic gauges. I can never seem to fill the tank without shooting fuel out of the air vent. The most I can put in is 28 gallons even when the gauge reads one bar. Is there a trick to fueling this boat. One day I actually took 20 minutes to fuel and got it to take 28 gallons. When I pulled out of the gas station fuel shot out of the air vent for the first few blocks. Are the Yamaha electronic LED fuel gauges historically reliable?
    Thanks
    Tom
    Sep 2004
    Ft. Lauderdale
    you probably have a 35-40 gal tank
    May 2011
    Ft. Lauderdale
    Hmmm,? Mine has a 72 gallon tank and she fills up properly. Are you filling up at a marina on the water? Or while it's on a trailer? If you are on a trailer, make sure it's not sitting with the bow tilting down. If the tow vehicle sits low and causes the boat to pitch toward the bow while on the trailer then the fuel tank wouldn't fill due to the pitch.
    Sep 2002
    Lakeland,Fla
    Its possible your gauge is not set right or your sending unit is not reading properly. I have a 92 Paramount and have no issues filling it.
    Fellow G-Man of the Sunshine Syndicate-Dixie Wrecked Chaptor..
    We Put The F. U. in FUN
    94 17MA Maverick 115 Yamaha
    2006 Mustang GT, with a belt driven air cleaner
    Sep 2009
    Miami
    Someone else told me about the pitch of the boat. I have been filling on the trailer. Going to make sure that it is level next time and check to see if that helps. Thanks for the replies. Anyone know what size tanks they were putting in Paramounts in 2003. I have seen people mention 40, 50 , 70.
    Thanks for all the info
    Tom
    May 2011
    Ft. Lauderdale
    Mine is '97, can't imagine you've got anything smaller than a 60gallon tank. The fuel coming out of the vent really makes me think it's the pitch while it's on the tow vehicle. Have you ever noticed any fuel coming out of the vent while in the water? If not, I'd bet good money it's the pitch scenario. You could just get a hitch receiver that has a few inches of rise to it at any trailer supply spot. Hope that's all it is. Would be the most simple/best resolution.
    Mine fills fine also. Pull your sender and see how much is actually in the tank.
    Sep 2009
    Miami
    Thanks for the info going to check this weekend. Baja, did you ever finish the bottom of your Paramount? If so, what type of speed did you get from taking the hook out.
    Thanks again
    Tom
    Removing the wedge helped a bit but since the whole bottom is a hook it is still limited. I have had 13 motors on it in a year, its the test boat and party barge. The only thing I do for setup is put the cooler in the back and pile 5+ people in it every weekend
    Sep 2009
    Miami
    Mine rides out pretty good. It will run 58 - 60 every day with the 200 VMAX, the seat in the rear and 12 inch stainless bracket may help. I may take the T Top off to see if it gains a few but I have not figured it out yet. My nephews rag me about my boat being a pig since they drive 18 Actions. But the boat just seems to ride, tube, ski and board great. I was just curious if you could ever hit those magic 21 Action Center Console numbers.
    Tom
    May 2011
    Ft. Lauderdale
    Did u ever figure out what he deal was with the fuel?
  12. #12
    Sep 2009
    Miami
    Going to do this next week. I want to compare angle of my current set up and see whether it is too high or to low and causing a problem while fueling. I have not hooked it up for a couple of weeks now.
    T
  13. #13
    Miami / Key Largo
    Mines an '07 and came with a 52 gallon tank. The issue your having sounds like the angle on the trailer (its happened to me).
  14. #14
    Sep 2009
    Miami
    I think it must be the angle. I misunderstood the earlier comments. I thought that I had to have more of a level angle of the boat. I believe now that my bow is too low on the trailer. I have a hitch with about a 4 inch drop and drive a 4 x 4 Lexus. I am going to go to a standard hitch and see if that changes things. That will actually raise the bow a hair.
    TIA
    Tom
  15. #15
    May 2011
    Ft. Lauderdale
    Quote Originally Posted by maineidyl View Post
    TIA
    Tom
    Betcha thats the solution. Now your gonna be shocked how much it REALLY costs to fill that tank up, lol. Damn fuel prices!
