Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
    Hopedale, IL
    Fuel Pump/Regulator Recommendation
    Guys,
    I'm wanting to ditch my VST on my 3L and go to a pump and regulator in the boat. I've been chasing fuel problems for damn near a year and I've bout had it. I want to be able to maintain constant pressure so I think I need a bypass regulator that has a return to tank. What are your thoughts?
    Nick
    Sunsation 32 Dominator - 496 MAG HOs
    Nothing runs like a Deere when a CAT's on it's ASS!
    Dec 2003
    Breaux Bridge, LA
    You need a back pressure reg. with a efi pump.
    Bosch is good stuff.
    XR2001 & XB2002
    Hopedale, IL
    Quote Originally Posted by malexie View Post
    A what?? I realize I need a regulator but I'd like one that returns excess fuel to tank.
    Mar 2007
    Tampa, Florida
    Call Tony & Linda B, they will steer you rite
    Doug (Enticer1)
    1998 Avon RIB with 9.9 Yammer
    Looking 4 another Mirage
    You want to use a Bosch 984 fuel pump (As merntioned Tony and Linda Brucato) sells them. And a Aeromotive regulator with the return port for the tank. Here's the one I use. And you will need a guage also. You can buy direct from aeromotive.
    13109 - A1000-6 Injected Bypass Regulator
    13109 - A1000-6 Injected Bypass RegulatorSKU: 13109
    Performance EFI regulator designed for medium to high horsepower applications. This regulators features Aeromotive’s high-flow design, superb pressure control and legendary durability. On the street and at the track, this pressure regulator has logged more miles, laps and passes than any other performance EFI regulator in the world!
    • Base pressure adjustable from 40-75 PSI.
    • Gasoline and alcohol compatible.
    • Fuel pressure rises on a 1:1 ratio with boost.
    • 1/8” NPT gauge port.
    • P/N 13109 provides (2) ORB-06 inlet ports and (1) ORB-06 return port.
    Download Installation Instructions
    <FORM id=product_18 class=product_form encType=multipart/form-data method=post name=1 action=http://aeromotiveinc.com/products-page/regulators/efi-regulators/13109-a1000-6-injected-bypass-regulator/ jQuery1331895201944="1">
    <!-- THIS IS THE QUANTITY OPTION MUST BE ENABLED FROM ADMIN SETTINGS --><INPUT value=add_to_cart type=hidden name=wpsc_ajax_action> <INPUT value=18 type=hidden name=product_id> <!-- END OF QUANTITY OPTION --></FORM>
    Hopedale, IL
    Ill need something a bit less pressure than that but I appreciate the insight, Bud. Need 34-36 PSI for this turd.
    So next question, what is WOT fuel burn on a 225 3L? Ive seen in the neighborhood of 26-27 GPH. Thinking a 35 GPH pump will suffice as long as it can make the pressure or should i step it up to a 43GPH?
    Not straying away from whats recommended above but $235 is a bit more than I. want to spend on a pump.
    OK then this one.
    13129 - EFI Bypass RegulatorSKU: 13129
    This EFI Bypass Regulator encompasses features and benefits only found on Aeromotive regulators and in a new smaller and lighter package. Capable of supporting applications up to 1000 HP, the 13129 EFI Bypass Regulator can handle high-flow EFI fuel pumps and the most aggressive street machines; especially those looking for a cleaner, lighter solution where performance is critical or where space is a premium.
    • Base pressure adjustable from 30-70 psi
    • Provides (2) ORB-06 inlet/outet ports and (1) ORB-06 return port
    • Vacuum boost port
    • CNC-Machined 6061 T6 billet aluminum construction
    • Stainless steel mounting bracket
    <FORM id=product_328 class=product_form encType=multipart/form-data method=post name=1 action=http://aeromotiveinc.com/products-page/regulators/efi-regulators/13129-efi-bypass-regulator/ jQuery1331896110433="1">
    <!-- THIS IS THE QUANTITY OPTION MUST BE ENABLED FROM ADMIN SETTINGS --><INPUT value=add_to_cart type=hidden name=wpsc_ajax_action> <INPUT value=328 type=hidden name=product_id> <!-- END OF QUANTITY OPTION --></FORM>
    Hopedale, IL
    Think I found a nice used Bosch pump! Now, I've heard people say you need a filter before a Bosch pump. I'm not a fan of putting a tight filter before a pump as it also can starve the pump. Would a ~200 micron screen be ok before the pump then a 10 micron filter after the pump?
    Thanks guys
    Nick
    I run a filter before and after with no problems. But my pump is mounted low in relation to the tank as not to tax it.
    Maurepas, Louisiana
    200 micron is kinda large, I use a 30 micron w/SS screen pre pump a a bosh 10 micron post pump. Tony has nice bosh10 mic filters and Jay Smith always suggests the Wix 10 mic filters..
    Russ Benton
    Allison XB-2003 w/JSRE Pro Max
    Allison XR-2001 w/260 +
  12. #12
    X2 on Wix filters!!!
  13. #13
    Hopedale, IL
    Is the Bosch pump that sensative to debris?? No need to worry on my post pump filter.... I got plenty of CAT stuff on the shelf....
    Bud, I'm going to mount the pump about the same level as the bottom of the tank so it'll have to draw up the pickup and down to my screen and into the pump. Seem ok?
  14. #14
    I run mine like this. Hose from tank to pre filter/water separator to pump, to post filter prior to injectors. The pre filter and pump is mounted low in relation to the tank.
  15. #15
    Jun 2009
    OK
    I use a 100 micron filter in front of my pump, and a 10 micron after.
