Results 1 to 15 of 16
    May 2002
    oshkosh-wi.
    Marine Polish for Black Gelcoat ??
    Hello. Whatīs the best marine polish for a Black
    Gelcoat ???
    Would like to use an easy & fast polish !!!! Opss..!
    Thanks,
    DON
    P.S. : Does "MOTHERīS" products make an A+ marine polishers ?
    Oct 2003
    Gun Lake MI.
    Is there a good amount of fade,or you just looking to add some nice shine..
    IF there's some fade I would start with 3M compound high gross cut....( comes in a gallon paint can ) it's white and almost like paste.Use only if your dealing with fade..
    Your almost doing a wet sand very nice and very mean cut...If there not a fade start with the 3m finesse cost a few bucks but well worth it...Hands down better then anything out there..
    Then use 3M FINESSE this adds a very nice and very clean polish..( steak free )
    Then any good wax after that..I use a wax with teflon.
    With it being black you will see some steak and lines after you take the wax off.after that take a damp micro fiber towel ( NEW ) and wipe your boat down.You will see nothing but a very nice shine left on your boat..Steak free..
    And the best thing about doing it with the right products is it will last...With a nice teflon wax you should only have to wax once every month or two..Me I still wax once a month..
    If you have questions after this send me a pm and I'll give you my number..
    Use a good wheel with a new pad white for compound and yellow for polish ( do not use a foam pad they work but they burn a little easier )
    AKA RACING JASON
    AKA THE KID
    AKA HOT ROD
    02' S.T.V RIVER ROCKET w/300 DRAG
    LIFE BEGAINS @ 100+ ON WATER
    May 2002
    oshkosh-wi.
    No, itīs not fade. Iīm looking to ad some nice shine !!! like "wet"!!!
    Does the polish with teflon are better than the carnauba ??
    Thanks
    Oct 2003
    Gun Lake MI.
    I would hit it with the 3M finesse turns it into Glass..( need a wheel & yellow pad )
    Teflon wax works great.Think about your non-stick pan ( teflon ) holds up to heat..
    AKA RACING JASON
    AKA THE KID
    AKA HOT ROD
    Woodstock, IL
    buff
    Here's my Eliminator I just finished buffing. Used 3M Perfect It II - 3M Finesse - Meguiars Marine wax. Super deep and super sexy!
    Attached Thumbnails Attached Thumbnails buff1.jpg   buff2.jpg   buff3.jpg   photo.jpg
    May 2002
    oshkosh-wi.
    NIce looking !!!
    May 2008
    Atmore, Alabama
    Lucas Slick Mist spray-on wax gives me excellent results. Really, really brings out the shine.
    Good info was going to do mine soon
    Sep 2002
    Like Kibbey said, polish first with Finnese-it or Meguiars Swirl Remover and Machine Glaze on a rotary wheel, nice and slow with medium pressure.
    Foam wheel works good for me on the rotary.
    If you polish it good first to smooth out imperfections, the waxing that follows will look much nicer.
    Nov 2003
    McHenry,IL
    Before
    After
    Reflection
    This is a Black Regal that had not been treated with wax yet. The customer has owned the boat eight years and has had many shops attempt to restore the color. "I have never seen my boat or any boat for that matter look this great" were his direct comments.
    Pm me for the product......
    www.bottomsupboatrepair.com
    847-
    587-5553
    Complete Service Center
    Jun 2009
    Bristol, Connecticut
    Looks like some great results. Can anyone recommend a polishing wheel tool to get from Harbor Freight?
  12. #12
    Nov 2003
    McHenry,IL
    Jun 2009
    Sorry I am very new to detailing but need to restore the gelcoat on the boat I bought. It is two tone, black bottom and red top. The gelcoat looks great when it is wet to give you an idea of the condition. It's like there is a white fuzz all on it and the red looks pink. So I was going to take the advice from above
    Steps
    first: 3M Compound high gloss cut
    second: 3M Finesse
    third: teflon wax
    Will the $70 6 in. 5.7 Amp Heavy Duty Dual Action Variable Speed Polisher from Harbor Freight work well? And what pads do I use on each step? Interchangeable pads?
    http://www.harborfreight.com/power-t...her-69924.html
  14. #14
    Sep 2002
    Get an RPM-regulated rotary (NOT orbital or D/A) and you'll get much better results. I use a Hitachi, Milwaukee also makes a good one, and I'm sure there's cheaper clones that still work well.
    A $50 Craftsman orbital/DA buffer works great for taking off wax.
  15. #15
    Jun 2009
    Is this what you have or will work?
    http://www.amazon.com/Hitachi-SP18VA...dp_ob_title_hi
    I also would like to know what pads should be used for each type of chemical
