Results 1 to 11 of 11
Thread: 2.5 reed cages
    longisland ny lindenhurst
    Question 2.5 reed cages
    Whats going on guys,alright i got a question for whoever can answer it.I got a 2.4bridgeport with 7peddle boysen reeds.I just got my hands on a set on 7peddle cages outta a 2.5 260.The ports have been machined larger then my other 2.4 cages.Will the 2.5 cages ruin my proformance or will they work better?I turn the motor around 73-7500ish with the 2.4 cages.So b4 i throw these in my mota just wondering if any can give me advice
    thanks
    edd
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt 300 yamaha!
    Old River , Texas ( 35 mi East of Houston )
    I machine the hour glass shaped earlier style reed cages to the newer rectangle shape all the time it works great, run em...
    Jay
    Jay @ JSRE
    Springfield,La.
    Tha 2.4 cages ARE smaller than tha 2.5 7 peddle gages in stock form...The actuall opening ov tha intake iz smaller than tha 2.5...If U put 2.5 cages on that 2.4 manifold, it won't do ya much good, and even may hurt flow kuz ov tha mismatch!!!
    thanks for the advice Jay and Rex.
    i had the manifold sent out and cross drilled about a year ago,and got 96s n 98s jets in a set of big bore carbs.i hope they work it took me a long time to find these cages and $ that i didnt have!
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    Sep 2006
    Key Largo, Fl
    Rex has your answer,for sure,and in my opinion the stock 7 petal Bp cages are more than adequate for 7500 rpm's,you might like my reeds better....,Chris
    Just did a set of hour glass shaped to new style shape last week with the Tony Doukas Reed valves attached , the customers loved them...
    Opinions, Everybodys got one like this customer .......
    Reeds and blocks
    <nobr>Monday, December 19, 2011 7:58 PM</nobr>
    "Chris Seigler" <chrisseiglerflw@gmail.com>
    Add sender to Contacts
    To:
    hitman6563@yahoo.com
    "Hey Jay I got my blocks and reeds in and my boat and my boat runs great a lot more snappy out of the hole and a little more on the top end.. Thanks so much for the help..do you sell oil pump block off plates?"
    Thanks chris seigler
    </chrisseiglerflw@gmail.com>
    Jay @ JSRE
    Aug 2009
    savannah,ga
    I run the 260 blocks in my carb 2.5 and dont have any complaints about em besides the crappy idle but if ya start in gear it dont matter. The more compression you have the more you will notice all the intake/exaust work you do to a motor. I'd stick em in there and run em.
    Johnboy,
    Try the TDR reeds they should have a better idle and I'll meet or beat anyones prices.......
    Jay
    Jay @ JSRE
    Aug 2004
    Venice, Florida
    Quote Originally Posted by Chris Carson's Marine View Post
    Try Chris' reeds. You wont find better products and support after (or before) the purchase and I am a picky S.O.B.
    I have a small Yamaha NOT a small Johnson
    Sep 2002
    Dunlap,TN.
    Quote Originally Posted by Mr. Demeanor View Post
    +1.... I use CCMS on my engine with 0 complaints.
    James Perry
    Bedford, PA
    Chris Carson Reeds and service second to NONE.
